Microtech third gen base map
Old Jun 21, 2008 | 08:54 PM
extreme_rotary's Avatar
third gen base map
Hey guys, i'm looking for a base load & crank map for my car; i recently rebuilt the motor and changed injectors from 850cc all to 1600cc secondaries, and i half-bridge ported it. i can't get the thing to start, and i was just looking for a baseline map so the thing will fire up, and i can tune it from there. i turned the fuel pressure regulator to about 35psi. i'd really appricate any help, as i said, i'm just looking for a baseline 'cause i've gone through one starter and a set of spark plugs already... wants to start, but i just can't get the fuel right. thanks.
Old Jun 22, 2008 | 03:56 AM
rx72c's Avatar
Top Answer: 1
your post confuses me.
so you have 2 850cc and 2 1600cc?
or 4X1600cc?
Old Jun 22, 2008 | 09:46 AM
i have 2-850cc and 2-1600cc
Old Jun 23, 2008 | 06:32 PM
rx72c's Avatar
Top Answer: 1
Idle Map
Screen 1
30" ~ 1.38
25" ~ 1.48
20" ~ 1.33
15" ~ 1.71
10" ~ 1.71
05" ~ 1.62
00" ~ 2.00
2-20psi ~ 4.95
Load Map
Screen 3
30" ~ 0.95
25" ~ 1.19
20" ~ 1.33
15" ~ 1.71
10" ~ 2.14
05" ~ 2.57
00" ~ 2.86
2psi ~ 2.2
4psi ~ 3.05
6psi ~ 3.7
8psi ~ 4.1
10psi ~ 4.7
14psi ~ 5.2
16psi ~ 5.6
18psi ~ 5.8
20psi ~ 6.2
RPMwot Map Screen 17
5000 ~ 05
5500 ~ 08
6000 ~ 08
6500 ~ 10
7000 ~ 11
7500 ~ 11
8000 ~ 11
9000 ~ 12
The rest are zero
RPMcrs Screen 18
1000 ~ -12
1500 ~ -11
2000 ~ -12
THe rest are zero
Pump Map
Screen 19
Pump2Start ~ 2000
Pump1Amt ~ 00
Pump1Pulse ~ 04
Pump1Trig ~ 18
Pump1Stop ~ 00
Pump1Adv ~ 05
Pump2Time ~ 10
Pump2Amt ~ 30
Pump2Trig ~ 16
Pump2Stop ~ 00
Pump2Adv ~ 05
PumpDwell ~ 3.00
PumpTimers ~ No
Pump1Sync ~ No
PumpSpare ~ 00
PumpCold ~ 00
Water Map
Screen 20
-25 ~ 0
-17 ~ 70
-9 ~ 60
-01 ~ 50
05 ~ 45
11 ~ 45
18 ~ 42
24 ~ 34
31 ~ 26
38 ~ 24
46 ~ 19
60 ~ 12
68 ~ 06
82 ~ 0
99 ~ 0
124 ~ 0
Air_t Map
Screen 21
-25 ~ 0
-17 ~ 8
-9 ~ 6
-1 ~ 5
5 ~ 4
11 ~ 3
18 ~ 3
24 ~ 0
31 ~ 0
38 ~ 0
46 ~ 0
60 ~ 0
68 ~ 0
82 ~ 0
99 ~ 0
124 ~ 0
Crank Map
Screen 22
-25 ~ 72
-17 ~ 72
-9 ~ 72
-1 ~ 67
5 ~ 62
11 ~ 57
18 ~ 50
24 ~ 41
31 ~ 31
38 ~ 26
46 ~ 20
60 ~ 15
68 ~ 5
82 ~ 0
99 ~ 0
124 ~ 0
t*rpm
Screen 23
Idle ~ 20
1000 ~ 20
1500 ~ 20
2000 ~ 20
2500 ~ 25
3000 ~ 25
3500 ~ 25
4000 ~ 25
4500 ~ 25
5000 ~ 25
5500 ~ 25
6000 ~ 25
6500 ~ 25
7000 ~ 25
7500 ~ ??
8000 ~ 25
9000 ~ 25
t*map Map
Screen 24
Idle ~ 00
25 ~ 05
20 ~ 04
15 ~ 03
10 ~ 02
05 ~ 00
00 ~ 00
2psi ~ 00
4psi ~ 00
6psi ~ 02
8psi ~ -04
10psi ~ -06
14psi ~ -10
16psi ~ -12
18 psi ~ -16
20 psi ~ -20
t*air Screen 25
Correction value Is expressed as number of degrees you wish to advance or Retard to the Ignition curve and values Is set at zero.
t*gap
Screen 26
0500 ~ 15
1000 ~ 15
1500 ~ 15
2000 ~ 14
2500 ~ 12
3000 ~ 10
3500 ~ 10
4000 ~ 10
4500 ~ 10
5000 ~ 10
5500 ~ 10
6000 ~ 10
6500 ~ 10
7000 ~ 10
8000 ~ 10
t*Inj Map
Screen 27
0500 ~ 120
1000 ~ 150
1500 ~ 150
2000 ~ 150
2500 ~ 150
3000 ~ 150
3500 ~ 150
4000 ~ 150
4500 ~ 180
5000 ~ 210
5500 ~ 210
6000 ~ 240
6500 ~ 240
7000 ~ 270
8000 ~ 270
9000 ~ 270
t*wat Map Screen 28
ANd the rest are zero
Option Map
Screen 30
Af_StE ~ 10
Dwell ~ 3.25 *set at Time Base - not at Duty Cycle*
REVstg ~ 1320
MAPstg ~ 02"
%stg ~ 50
My map techinically isnt going to make your car start.
Take the spark plugs out.
Squeeze some oil in to the leading holes(front and rear rotor). then stick the plugs back in it. put my map in it. see how you go.
Old Jun 24, 2008 | 07:31 AM
i fired her up yesterday; had to pull start her, afterwards she was good until she flooded one rotor lol. i'll try your map, and see if she'll idle. thanks again.
Old Jun 24, 2008 | 06:27 PM
rx72c's Avatar
Top Answer: 1
my map wont flood your engine.
Did you try some oil in the spark plugs? that will eliminate the need to pull start.
Old Jul 18, 2008 | 11:42 PM
jacoolv6's Avatar
"Street Ported"
Wat would be a good base map in a street port engine 2 850cc and 2 1600cc with stock twins on a lt10 with the x4
Old Jul 20, 2008 | 05:43 PM
rx72c's Avatar
Top Answer: 1
use the above map.
Old Jul 26, 2008 | 02:04 PM
jacoolv6's Avatar
"Street Ported"
Are you running an lt10? Did you had to put any resistors on the injectors or it didnt need it? Also do you have the x4 box for the coils?
Old Jul 28, 2008 | 01:03 AM
rx72c's Avatar
Top Answer: 1
no need for any resistors.
Old Aug 13, 2008 | 03:37 PM
vmarx7@yahoo.com's Avatar
? for rx72c, can i use this map on a S5 pport?it has the same size injectors but i'm using a mt4 or can you supply me with one?THANKS!!
Old Aug 14, 2008 | 09:33 PM
rx72c's Avatar
Top Answer: 1
peripheral port?
What injectors do you have?
Old Aug 15, 2008 | 03:48 PM
yes peripheral port and i have 850 & 1600cc injectors.
Old Aug 15, 2008 | 05:49 PM
rx72c's Avatar
Top Answer: 1
I will upload another map that is slightly modified for the pp
Idle Map
Screen 1
30" ~ 1.38
25" ~ 1.48
20" ~ 1.33
15" ~ 1.71
10" ~ 1.71
05" ~ 1.62
00" ~ 2.00
2-20psi ~ 4.95
Load Map
Screen 3
30" ~ 0.95
25" ~ 1.19
20" ~ 1.33
15" ~ 1.71
10" ~ 2.14
05" ~ 2.57
00" ~ 2.86
2psi ~ 2.2
4psi ~ 3.05
6psi ~ 3.7
8psi ~ 4.1
10psi ~ 4.7
14psi ~ 5.2
16psi ~ 5.6
18psi ~ 5.8
20psi ~ 6.2
5000 ~ 05
5500 ~ 08
6000 ~ 08
6500 ~ 10
7000 ~ 11
7500 ~ 11
8000 ~ 11
9000 ~ 12
The rest are zero
RPMcrs Screen 18
1000 ~ -12
1500 ~ -11
2000 ~ -12
THe rest are zero
Pump Map
Screen 19
Pump2Start ~ 2000
Pump1Amt ~ 00
Pump1Pulse ~ 04
Pump1Trig ~ 18
Pump1Stop ~ 00
Pump1Adv ~ 05
Pump2Time ~ 10
Pump2Amt ~ 30
Pump2Trig ~ 16
Pump2Stop ~ 00
Pump2Adv ~ 05
PumpDwell ~ 3.00
PumpTimers ~ No
Pump1Sync ~ No
PumpSpare ~ 00
PumpCold ~ 00
Water Map
Screen 20
-25 ~ 0
-17 ~ 70
-9 ~ 60
-01 ~ 50
05 ~ 45
11 ~ 45
18 ~ 42
24 ~ 34
31 ~ 26
38 ~ 24
46 ~ 19
60 ~ 12
68 ~ 06
82 ~ 0
99 ~ 0
124 ~ 0
Air_t Map
Screen 21
-25 ~ 0
-17 ~ 8
-9 ~ 6
-1 ~ 5
5 ~ 4
11 ~ 3
18 ~ 3
24 ~ 0
31 ~ 0
38 ~ 0
46 ~ 0
60 ~ 0
68 ~ 0
82 ~ 0
99 ~ 0
124 ~ 0
Crank Map
Screen 22
-25 ~ 72
-17 ~ 72
-9 ~ 72
-1 ~ 67
5 ~ 62
11 ~ 57
18 ~ 50
24 ~ 41
31 ~ 31
38 ~ 26
46 ~ 20
60 ~ 15
68 ~ 5
82 ~ 0
99 ~ 0
124 ~ 0
t*rpm
Screen 23
Idle ~ 35
1000 ~ 20
1500 ~ 20
2000 ~ 20
2500 ~ 25
3000 ~ 25
3500 ~ 25
4000 ~ 25
4500 ~ 25
5000 ~ 25
5500 ~ 25
6000 ~ 25
6500 ~ 25
7000 ~ 25
7500 ~ ??
8000 ~ 25
9000 ~ 25
t*map Map
Screen 24
Idle ~ 00
25 ~ 05
20 ~ 04
15 ~ 03
10 ~ 02
05 ~ 00
00 ~ 00
2psi ~ 00
4psi ~ 00
6psi ~ 02
8psi ~ -04
10psi ~ -06
14psi ~ -10
16psi ~ -12
18 psi ~ -16
20 psi ~ -20
t*air Screen 25
t*gap
Screen 26
0500 ~ 15
1000 ~ 15
1500 ~ 15
2000 ~ 14
2500 ~ 12
3000 ~ 10
3500 ~ 10
4000 ~ 10
4500 ~ 10
5000 ~ 10
5500 ~ 10
6000 ~ 10
6500 ~ 10
7000 ~ 10
8000 ~ 10
t*Inj Map
Screen 27
0500 ~ 120
1000 ~ 150
1500 ~ 150
2000 ~ 150
2500 ~ 150
3000 ~ 150
3500 ~ 150
4000 ~ 150
4500 ~ 180
5000 ~ 210
5500 ~ 210
6000 ~ 240
6500 ~ 240
7000 ~ 270
8000 ~ 270
9000 ~ 270
t*wat Map Screen 28
Option Map
Screen 30
Af_StE ~ 10
REVstg ~ 1320
MAPstg ~ 02"
%stg ~ 50
Old Aug 17, 2008 | 09:52 AM
rx72c your map has made a world of difference but it runs rich thru out the entire rev range.Can you adjust the maps to lean out some?What screens/maps should i be looking at to adjust for final tunning?Also my o2 senor reads 14.7 afr all the time.I replaced it/ checked the wiring but still reads that ratio what could be wrong?THANKS!!
Old Aug 17, 2008 | 07:09 PM
rx72c's Avatar
Top Answer: 1
you need a proper wide band sensor.
What makes you think its running rich?
You use the load map to lean out both cruise and WOT and the idle map to adjust the idle.
Old Aug 18, 2008 | 10:16 AM
i'll break down a get a wide band sensor.Strong exhaust fumes leads me to think its running rich.I'll play with maps see if can lean it out some.THANK YOU!! for all of your assitance.
Old Aug 18, 2008 | 07:00 PM
rx72c's Avatar
Top Answer: 1
exhaust fumes?
lol you got a pp.
that map should actually be very good in terms of mixtures.
Old Aug 19, 2008 | 03:45 PM
U R THE MAN!!
That map is very good as you stated, but i don't want to be fooling around with the settings too much i'm new to FI and don't need anymore headaches,must be from all the fumes?
I'll keep you updated and i owe you a bunch of for your services.THANKS!!
Old May 6, 2009 | 07:43 AM
james81's Avatar
Could i use the same map u recommended for jacoolv6, who has street ported motor with 850s and 1600s with stock twins, while I also have a street ported motor but Im using stock injectors atm with a GT35R single turbo setup?
Or should i use that map but just richen it up all round? by how many points richer too?
Thanks
Old May 6, 2009 | 06:45 PM
rx72c's Avatar
Top Answer: 1
Stock injectors is a different map.
Message me and ill put a map together for you. I need as many details as possible.
Old May 12, 2009 | 11:43 AM
james81's Avatar
hows that map comin' on rx72c?
Old May 12, 2009 | 05:28 PM
rx72c's Avatar
Top Answer: 1
Sorry man? I dont think i got a pm from you with all your details?
Send through your details.
Old May 19, 2009 | 02:38 AM
james81's Avatar
Sorry, i sent it twice, ill try again now.
Here's the message i sent anyway incase it doesnt go through.
Thanks a lot hey.
Base map for GT35R FD
Hi,
thanks in advance for your time. It's really nice to see someone who knows that microtech system helping guys out so much, good on ya!
I'v got a 93FD, fresh motor still running atm.
Street Ported
GT35R (0.64 a/r hot side)
MicroTech LT10s (Im using a dynojet wideband for AFR off one of my race bikes, abt the best wideband system you can buy)
Stock injectors
Pettit Coolcharge SMIC (AIT abt 45degC/113degF)
It's battling to hold a steady idle for longer than abt 5sec before it leans out, big flat spots as you touch the throttle it leans out, then super rich. Main problem im having is when its in vacuum, AFR is all over the show and stumbles a lot.
What are the ideal AFRs for boost and vacuum?
Is there a process I need to go through to save the map to the ecu once I'v typed all the values in? Or do i just unplug the laptop and dongle?
Thanks,
James81
Old May 19, 2009 | 05:43 AM
rx72c's Avatar
Top Answer: 1
Ok i got that pm.
It would be easier if you can do a screen capture of your existing map. And i can fix it up for ya.
connect your laptop and do a screen capture of EVERY SINGLE MAP and ill tell you what to change.
24seven_dada
20
Nov 10, 2018 12:03 PM
befarrer
Sep 4, 2015 08:26 PM
