silver wire from exhaust?
Old Jun 19, 2008 | 03:15 PM
blackdeath647's Avatar
weak minds wear the crown
while looking for the cause of my statiky sound coming from stereo i found out that when i was taking my tranny out i must have accidentally pulled a silver wire out. it goes from around the cat area to somewhere inside the car, idk what it plugs into, i was wondering if you guys could tell me, thanks.
Old Jun 19, 2008 | 03:57 PM
yetterben's Avatar
7less for now!
exhaust over heat sensor maybe!
Old Jun 19, 2008 | 04:02 PM
Jeff20B's Avatar
Lapping = Fapping
Yeah, you must have an '84-'85 car.
Old Jun 19, 2008 | 04:07 PM
yeah it's an 85, but uh, where does it plug into, do i have to take the driver side container box out?
Old Jun 19, 2008 | 04:17 PM
Jeff20B's Avatar
Lapping = Fapping
I used to know what it's called but I think it's the exhaust overheat sensor like Ben said. I simply took a small piece of steel, drilled two holes in it and stuck it on the exhaust flange when the connecting pipe went into an '83. As for the '84 car, it got a different exhaust and I simply used some mechanic's wire to tie the sensor probe thing up out of the way. It didn't affect anything.
Old Jun 19, 2008 | 04:19 PM
yetterben's Avatar
7less for now!
except when you park over leaves for extended periods of time lol it does nothing. You would know your exhaust was that hot way before that light came on!
Old Jun 19, 2008 | 04:32 PM
Jeff20B's Avatar
Lapping = Fapping
Cooking grass smells kinda good, when you're in the right mood I guess.
Old Jun 19, 2008 | 05:07 PM
thank you guys
Old Jun 19, 2008 | 07:09 PM
Sgt Fox's Avatar
Stigulus Moderatorai
I thought that was the cat overheat sensor. The exhaust overhead sensor that triggers the dash light is on the floorboard?
streetlegal?
Mar 17, 2022 02:46 PM
BNR34RB26DETT
42
Feb 28, 2018 11:27 AM
