17x9 lowered with JIC Oem FC fenders ?
Old Jun 19, 2008 | 11:05 AM
FS_WTB's Avatar
Enkei RPF1 17x9 +22 would it fit into the FRONT?
do i have to roll my fenders? if so, how much?
also, can i run 255 tires in the front?
thanks
Old Jun 19, 2008 | 11:46 AM
coxxoc's Avatar
Shooting for 500
The short answer is yes. You would need to pull the fender about 20mm which would have a crazy big lip on it. To fit a 255 up front you would need about a 5mm spacer to clear. See this thread for proper fitments for RPF1 on FC:
https://www.rx7club.com/showthread.php?p=8298948
Old Jun 19, 2008 | 12:11 PM
Jaiyurai's Avatar
Endure Persevere Succeed
What are JIC OEM FC fenders?
I have the 17x9 +22 RPF1s right now.
You have to minimum roll the lip. A slight pull would help. A 255 tire in the front will be tough to fit even with coilovers and massive camber.
For that width tire up front, you should just go with aftermarket wide fenders. Save time and money.
Old Jun 19, 2008 | 12:36 PM
coxxoc's Avatar
Shooting for 500
Right, the tire size is what will kill you. I run 235's up front without issues on a rim setup that should have the same spacing between the back side of the wheel and the coilover.
Old Jun 19, 2008 | 02:37 PM
Prometheus's Avatar
Still got it.
Originally Posted by Jaiyurai
What are JIC OEM FC fenders?.
I think he is saying his car is on JIC suspension, with OEM fenders.
Old Jun 19, 2008 | 08:22 PM
Jaiyurai's Avatar
Well then, seeing you want to keep stock fenders, then I'm guessing this isn't a race car. So you don't need the 255s up front. Stick with a 225/45/R17 or 235/40/R17 in the front.
I had thought this would be a race type setup needing the wide 255 up front, but there's really no logical way to do that on an FC with stock fenders.
Old Jun 20, 2008 | 12:20 AM
Josh18_2k's Avatar
this is how you fit 255's. good luck making it pretty...
(pic is actually a 245s, but you get the idea)
Old Jun 28, 2008 | 02:25 AM
RedFox's Avatar
VW ProRacer
Do it the right way.
http://www.mariahmotorsports.com/ext..._epfenders.htm
The MARIAH Mode Five Front fenders were initially designed for our SCCA E-Production race cars, but we found they looked great on street RX-7s as well. These slightly wider front fenders (1.25" per side; 69.25" width overall) allows one to run equal width rims front and rear, without the rim width being determined by the narrower front fenders. These are a direct replacement (bolt-on) for the Mazda factory fenders! Please call us for full details.
Old Jun 28, 2008 | 04:53 PM
Josh18_2k's Avatar
^ esspensive but super nice! and wider than the typical 20mm ones all over ebay.
