Sponsored by: CARiD
Starts, Fires up, then dies (searched)
Old Jun 15, 2008 | 11:44 PM
10AEFC's Avatar
hey guys, so i've searched for hours and found a bunch of issues and don't know which one to believe
so after replacing o rings in lower exh. manifold, put upperintakemanifald and others back together, checked vacuum linesx2...
my car starts, ignites, goes to 1k~1.5k, then dies(gassing the pedal has no effect) ! But then if starter fluid is sprayed into the car it stays and idles, but throttle still will not work also
what is going on? i smell fuel though so fuel pump should be working.
My car is an s4 88 10thae
Old Jun 16, 2008 | 01:56 AM
RotaryBred's Avatar
Lost You in the Rear View
is there anyway to check your fuel pressure? sounds like you are getting just enough fuel to start but not enough to keep it running. something tells me that it dies faster when u give it gas
Microtech
30
Apr 23, 2016 06:37 PM
alphawolff
Nov 17, 2015 05:57 PM
1993fd3sracer1
29
Oct 13, 2015 01:57 PM
1993fd3sracer1
20
Sep 7, 2015 11:50 AM
