New Engine, Old Gas
Old May 2, 2002 | 12:14 PM
Jedon's Avatar
Slave2TheFD
New Engine, Old Gas
The car has not ran since Aug 2001, and I'm about to start up the new engine. Is the old gas okay? Should I put more in? Additives?
Thanx!
-Jedon
Old May 2, 2002 | 01:55 PM
Jedon's Avatar
Slave2TheFD
Gas is good, gas is good *boom*
anyone?
Old May 2, 2002 | 02:01 PM
jmseven's Avatar
Asset is Wealth
you should be fine. Drop in injector cleaner on the NEXT tank fill.
Let you car idle for awhile. Tune it. Then run it around for awhile under light loads. Then tune it....then.....you know. Then After 500miles....start using the RPMs. Do not overboost. Let the seals seat.
Old May 2, 2002 | 02:09 PM
DomFD3S's Avatar
Mod Powers...gone!
The gas itself should still be okay. Just make sure to NEVER let your tank run low because of all the sediments that are on the bottom.
You could take the extra step and clean your fuel tank. Go to a shop that specializes in restoring old vehicles. They can probably get your fuel tank scrubbed and cleaned for you.
Old May 2, 2002 | 02:37 PM
Jedon's Avatar
Slave2TheFD
jmseven: tune it? The engine will be 100% stock until I pass smog :-)
DomFD3S: akkk, sounds lieka real pain, I'd get a fuel cell instead :-D
Old May 2, 2002 | 02:39 PM
jmseven's Avatar
Asset is Wealth
Tune it...ya know...Timing, TPS, etc...the normal stuff.
Old May 2, 2002 | 02:43 PM
Jedon's Avatar
Slave2TheFD
How would I change that stuff with the stock ECU?
I guess I could put my PowerFC on instead, and I might just so I can use the sensor readouts.
Old May 2, 2002 | 02:48 PM
mkoch1's Avatar
old gas
If you are real worried you can buy a gas siphon from places like track auto for 4-5 dollars.
Old May 2, 2002 | 02:57 PM
Mahjik's Avatar
Mr. Links
You should be fine. However, I would personally take a few long trips though to get that gas out of the car as soon as I could.
Old May 2, 2002 | 03:10 PM
Jedon's Avatar
Slave2TheFD
So drive it until empty and then put new gas with injeector cleaner in it?
I think it has about a 1/4 tank now.
Old May 2, 2002 | 03:17 PM
Rx7aholic's Avatar
Dude u should have send out your injector to RC- Engineering to get cleaned and recalbrate for optium performance. I think that is why most guys on this forum is on they 3rd engine because no one never mention when u get a new engine put in also send out your injector to be clean. I glad when I did my engine I send out my injector to be cleand because one of the secondary was stuck closed, and can u imagine after the break in what can possibley happen to my new engine, WOT bang =engine=dead, because at wot u need the secondary to work as good as they get. Sorry for the long post but I just want to give u my rule of thumb. khris
Old May 2, 2002 | 03:28 PM
djantlive's Avatar
Just fill it up @ the gas station after you start it. Put some gas stabilizer next time the car sits longer than a month.
Take it easy on the car since you've got old gas and new engine. You gotta break in that engine for 500 mi anyways.
Old May 2, 2002 | 03:30 PM
Jedon's Avatar
Slave2TheFD
yeah no boost for me for 500 miles, gunna be hard :-)
After I break it in, the secondaries will be the primaries and I have RC eng. bored 850->1200cc for the secondaries to go with my single setup.
Old May 2, 2002 | 05:14 PM
djantlive's Avatar
Jedon must be pimping!
Old May 2, 2002 | 05:20 PM
Jedon's Avatar
Slave2TheFD
Well not really, I don't actually have the single yet just the 1200cc injectors, TiAL BOV, Profec A, PFS IC, resonated midpipe and GReddy catback :-D
I need to sell my old engine to pay for the single.
Rotospectre
Mar 28, 2018 03:33 PM
82streetracer
Aug 23, 2015 09:28 AM
smikels
Aug 18, 2015 01:26 PM
