windows falling out
Old May 2, 2002 | 12:21 AM
russerts's Avatar
windows falling out
On my '85 GSL-SE, the window regulators appear to be badly worn - if you close the doors with the windows anyplace but all the way up, they come out of the tracks and you have to remove the door panel, take out the front track mounting bolt, and put it back. Anyone found a way to tighten this linkage up without having to buy the whole new part?
Thanks!
Old May 2, 2002 | 12:41 AM
BadAssRX-7's Avatar
The AUTO DOCTOR
you sur its not the little plactis clip things on the glass to the reg.? that has always been my finding when a window pops out of the track
Old May 2, 2002 | 03:26 AM
DONNA's Avatar
i had the same trouble, the front track mounting bolt that holds the vertical track, well i just drilled another hole inward about 1/2 inch to take up the slack in the window,, now no more lost windows,, also put some lube on the track,,,works great no more haveing to guide or push on the windows when they go up ......
Old May 2, 2002 | 04:31 PM
SuperPhly's Avatar
Does this problem happen with powered windows?
Old May 3, 2002 | 05:55 AM
DONNA's Avatar
yep.
Old May 3, 2002 | 08:41 AM
damon's Avatar
you could also try the redneck south georgia thing and jb weld it to the track (lol) j/k
Old May 6, 2002 | 09:07 AM
russerts's Avatar
Well, I found a solution this weekend, although it is probably a temporary one. Looking at what was going on, I finally realized that the window rocks down at the front as it lowers, making it 'shorter' so that it doesn't go into the front track anymore. I took the mechanism out of the door, and found that there was a lot of play in the pivot points. I was contemplating making new pins to hold the rollers, replacing or bushing the little nylon rollers, etc. when I realized one major part of the slack was from the pins rocking back and forth. I held the whole mechanism over the vise with the pin over the flat part of the vise and whacked it smartly with a good-size ball pein hammer a few times, and Hey! it works. I greased it up real good, and I'm hoping it lasts. Since Sept. 11th, we now have a guard gate coming on to the company campus, and I have to roll the window down every morning to show my employee ID. - too embarassing to open the door and reach over!
DocHoliday89
Power FC Forum
11
Feb 18, 2018 01:35 AM
He's On Toroids
NE RX-7 Forum
48
Oct 19, 2015 08:58 PM
turbojeff
Oct 5, 2015 10:50 AM
