17x10 wheels on stock fd
Old Jun 6, 2008 | 06:57 PM
A_Shadow's Avatar
Will the wheels fit in the back? If not what is the biggest I can go without problems?
I appreciate the help thanks
Old Jun 6, 2008 | 06:59 PM
RX7 RAGE's Avatar
Bann3d. I got OWNED!!!
Top Answer: 1
Did you mean 17x10?
Old Jun 6, 2008 | 07:15 PM
NTIMD8's Avatar
Yes a 17x10" wide wheel will fit the rear no problem with the correct offset.
Old Jun 6, 2008 | 10:13 PM
A_Shadow's Avatar
Awesome. Thanks a lot guys.
Old Jun 7, 2008 | 08:26 PM
matty's Avatar
what offsets are u looking to do? how wide a tire as well?
Old Jun 12, 2008 | 12:01 PM
revvin7Ed's Avatar
yea there definitely needs to be more info. offset, tires. i think it should fit.
Old Jun 16, 2008 | 01:16 AM
michael_iler's Avatar
post pics and specs when they are on.
Old Jun 16, 2008 | 07:01 PM
My old set of Fikses were 17x10 with a 275/40 out back, +45 offset. No issues, but I do have coilovers and RE trailing arms.
Old Jun 18, 2008 | 11:51 PM
apex_sideway's Avatar
FD dream is dead
There's a guy on here named AHarada with a FD that uses 17x10+35 with 255's all around.
Old Jun 19, 2008 | 07:40 AM
matty's Avatar
a few guys are doing it. i ordered this setup. yet i have my doubts. big doubts. as i was having trouble fitting 8.5 +40 with 235 on the front granted my fender isnt rolled and i plan to do that but we are talking a muhc much bigger setup now.
Old Jun 19, 2008 | 08:30 AM
Matty, I ran 245/40s on a 17x8.5 +38 Fikse for many many years with no problems at all. I had the ride height very low too
Old Jun 19, 2008 | 10:46 AM
matty's Avatar
wierd i guess every car is diff.
Old Jun 19, 2008 | 10:58 AM
Mahjik's Avatar
Mr. Links
Rich most likely had/has his fenders rolled as well. You would have been fine with your fitment had your rolled the fenders. IMO, if you are going with aftermarket wheels, just get the fenders rolled.
Old Jun 19, 2008 | 11:09 PM
Nope, stock unrolled fenders.
Old Jun 20, 2008 | 10:06 AM
Mahjik's Avatar
Mr. Links
Then yours must have been bent up already a little more than normal. I grabbed the fender lip every drive when I ran 17x9 +43 with 255's. I even picked a tire that was a little smaller to aid in rubbing but in the end, I had to roll the fenders (which I should have done to begin with).
Old Jun 20, 2008 | 07:43 PM
NeoTuri's Avatar
The shy megalomaniac
I run 275's on a 17x9.5 +43 wheel in the rear.
The tires haven't touched the fenders yet, but I also run 500lb springs back there.
Old Jun 20, 2008 | 08:02 PM
cwhiteteg's Avatar
Newbie
I dont see why it wont
cristoDathird
28
May 30, 2019 08:47 PM
BNR34RB26DETT
42
Feb 28, 2018 11:27 AM
