I want to weld my wheels shut!
Old Jun 5, 2008 | 05:37 PM
Alex Rodriguez's Avatar
MODERATOR
Veteran: Marine Corp
I have 3 piece wheels they keep on leaking on me, i have spent more money removing the tires and putting them back on, when i could of gottenb them welded shut.
Does anyone know a place who will do this for me.
Old Jun 5, 2008 | 05:48 PM
Josh18_2k's Avatar
anywhere that tig welds im sure..
isnt there some kinda sealant that can be put in there?
Old Jun 5, 2008 | 05:55 PM
MODERATOR
yeah 100% silicone, i dont know whats going on, when i got the wheels they all leaked i rebuilt them all and now 1 leaks completely and the other has a slow leak.
Its very frustrating when you have expensive wheels leaking and cheap china knock offs are working like a charm.
I havent even gotten into boost yet, i wonder whats going to happen when i hit it hard for the first time?
Old Jun 5, 2008 | 06:16 PM
onehalfasia's Avatar
you'll probably blow the welds on your intake manifold.
what wheels are they, i wouldnt weld them, especially when they're nice, call a wheel shop and ask what silicone to seal them with, and the proper method.
Old Jun 5, 2008 | 07:44 PM
BASTARD's Avatar
How did you assemble the pieces??? did you put silicone between each piece or did you put them together then put a bead around the seam???
Old Jun 7, 2008 | 06:40 PM
MODERATOR
i put the silicone in between each piece and then i use the cross patern when i tighten them
i am going to clean up the silicone once more and try dabbing the silicone in the grooves of the wheels , hopefully it will work
Old Jun 7, 2008 | 07:44 PM
BASTARD's Avatar
ahhhhh, that is your problem... you want to assemble the wheel pieces first... then put a bead of silicone around the seam
Old Jun 7, 2008 | 08:02 PM
MODERATOR
you serious bro, man i am going to get the tires removed this monday and i will clean them again and try that thanks bro
Old Jun 7, 2008 | 08:25 PM
BASTARD's Avatar
yeah... thats the way I sealed my wheels and they haven't leaked in over 2 years
*edit*
I scraped all the old crap off with a scotch bright pad then used some brake clean and then a little soap and water on the area where I was putting silicone... then let the silicone set/cure for 24 hours
Old Jun 8, 2008 | 11:49 PM
njstreetrx7's Avatar
nnnno u dont do it like that
heres the correct way
http://www.ccwheel.com/files/technical.php
next click wheel repair videos
and like he said let cure for 24hrs b4 u mount tire
Old Jun 9, 2008 | 12:28 PM
BASTARD's Avatar
nice video... but I got my method from a guy who is in the wheel repair business and like I said, I did mine over 2 years ago and they haven't lost any air
Old Jun 9, 2008 | 01:45 PM
killalot13601's Avatar
Use both said Methods. Then watch it not leak xD
Old Jun 12, 2008 | 11:58 AM
revvin7Ed's Avatar
if they are expensive 3 piece wheels they shouldn't be leaking like that. sorry to hear your wheels are causing problems. hope everything works out.
Old Jun 12, 2008 | 05:34 PM
BrandonDriftKing's Avatar
just wondering are you on two wheels in that sig? haha how did that feel?
Old Jun 12, 2008 | 05:57 PM
Josh18_2k's Avatar
3 wheelin
and i had no idea till i saw the pic lol
i guess thats what happens with stiff swaybars and wide tires
Old Jun 13, 2008 | 12:14 AM
mm.. uh one more thing.. what kind of rims do you have on your FC? i like them and want them lol...
Old Jun 13, 2008 | 01:21 AM
Josh18_2k's Avatar
fr500 (mustang wheels)
17x9/10.5
