6 X 1000 cc injectors and ground LIM
Old Jun 1, 2008 | 12:53 AM
hiboost's Avatar
Serbian
I'm going with T04r turbo and this is what I'm going with for fuel setup: 6x1000cc injectors groung LIM and 2X255hp walbro pumps plus Haltech E8 for tuning.
Any thoughts on this? Any suggestions?
Thanks
Old Jun 1, 2008 | 01:01 AM
whereiscarmensandiego's Avatar
my only thought that comes to mind is that is a friggen lot of fuel
Old Jun 1, 2008 | 01:24 AM
BASTARD's Avatar
what kind of power are you looking for?
Old Jun 1, 2008 | 02:10 AM
btleier's Avatar
ya.... wow. why would you need that much fuel.
Old Jun 1, 2008 | 02:53 AM
CyberPitz's Avatar
Boost ahoy!
Are you looking for a million HP?! D:
Old Jun 1, 2008 | 02:58 AM
Stanello's Avatar
backslash beanbagrace
Guys... 6000cc is not an outrageous amount of fuel, especially with E85
Old Jun 1, 2008 | 04:28 AM
hiboost's Avatar
Serbian
My current goal is 450whp on 91, and maybe down the road I get WI and go for 500whp. With 6 injectors I feel that I might have a better fuel control. 2 walbro pumps are there to make sure these injectors are 100% operational ...
Old Jun 1, 2008 | 06:11 AM
Are you running 1000cc primaries from the GZero LIM, or in the position of the original 550's? When I tried running 850 primaries from my GZero LIM it didn't work too well. Its the "position" that the stock 550 primaries inject that from gives much better throttle response and pickup from idle IMHO.
Also with 1000cc primaries the fuel pressure you'll need to run might be too low, and so may have an effect on the rest of your injection setup which will run at the same pressure. Unless you run 2 fuel regulators...1 for primaries and 1 for secondaries.
Old Jun 1, 2008 | 09:01 AM
RX72NR's Avatar
paying to play
Use 720s or 550s for primaries, 4x1000cc on the secondary rail.
Old Jun 1, 2008 | 09:51 AM
charlies7's Avatar
3rd rotors a charm
Look into a CJ motorsports fuel systems, they have a newly designed kit that allows you to meet your goals.
Old Jun 1, 2008 | 10:41 AM
glenrx7's Avatar
Building my car...
Well, this is our customer at AZRR, I am going to be running 6 1000cc injectors, these injectors are built by Paul Yaw of Yawpower.com. This is a fuel system that will support 620hp. The injectors are 1000cc high impendence injectors that can run at 1.2ms producing a clean and consistent idle. Also they can run any gas and e85. These are "dynoed injectors" this is good for specific injector information such as "battery dead time compensation" , "injector timing vs rpm". This setup is going to provide better tuning capabilities and more consistent fuel flow across the board.
These can also be run in parallel on a power fc setup due to the ohms resistances allowing two injectors per driver bank on the power fc. So with a ground zero manifold you can run six injectors with the power fc. No more need for resistors that have been proven to be unreliable. We are building a couple of these systems, they are new however we will be giving some impressive dyno information in the furture.
Now as far as the fuel amount many people are using two 1680cc and two 850cc injectors this is 5060cc and they are running out of fuel at high rpm and or high boost. 6000cc is fine if you can run it low enough to idle well and these Yawpower injectors are built for this.
I have attached a sheet Paul has provided for these new injectors, check it out
File Type: pdf
Old Jun 1, 2008 | 11:26 AM
Jodeny's Avatar
Indifferent
Glen,
Why not run 4 1680's in series and either 1000's or 750's (high imp) in the primaries. If you are looking for the most fuel, it seems like this may work for you. I have heard of some people using 1000's for primaries and they sem to work well without too many issues.
John
Old Jun 1, 2008 | 01:11 PM
glenrx7's Avatar
Building my car...
There are a few reasons I am using 6 1000cc instead of a 720cc...First is giving room for increased boost pressure with out upgrading injectors, Two is the transition on a haltech for example is going to be a ton smoother.
The atomization of these injectors are better than any low impedance injector. This gives better and more consistent performance, not to mention you don't need a super big pump to supply the volume and pressures needed in fact at the 620hp calculation we were assuming 45psi, with boost 55psi at the most.
Also, a big plus with these yawpower injectors is the dead time is much less than your typical low impedance or even your stock injectors, in other words this injector open and closes very fast with little drop time.
Think about this, at 8000rpm of a rotary engine, you have like 4millisec to inject fuel, if the injector take 2millisec to open you only have 2millisec left to spray fuel, at hat rpm with large amount of boost you could need 5millisec with a 1680 so you are only really getting 3millisec of fuel with the new injectos we have a fast reaction so we have more time to acually spray fuel.
Old Jun 1, 2008 | 01:54 PM
At 8000rpm shouldn't you have 7.5ms per cycle (360deg) to inject fuel, not 4ms? That would give you 6ms, if dead time is 1.5ms.
Old Jun 1, 2008 | 02:42 PM
glenrx7's Avatar
Building my car...
According to Paul Yaw its 4.6millisec at 8000 I need to do the math but I am sure thats the case. Eitherway the point is that a fast responce is better...
Old Jun 1, 2008 | 03:31 PM
glenrx7's Avatar
Building my car...
You must be talking rev per milisec, that being said you are not injecting all of that time.....You are not injecting the full 7.5millisec
If you have 8000rpm you would then devide 60sec by 8000 giving you 7.5 millisec, is this your math? You would not be injecting this entire time...
Old Jun 1, 2008 | 04:02 PM
glenrx7's Avatar
Building my car...
Sup Charlie.... We are of course are using CJ-motorspots dual pump bracket, I am working with Charles and Brandon, hopefully they will be able to offer this 1000cc injector with there fuel rails in the future.
Old Jun 1, 2008 | 07:52 PM
TweakGames's Avatar
FD pro licensed driver
Are these special yaw power injectors available to be purchased by normal people?
Old Jun 1, 2008 | 08:17 PM
glenrx7's Avatar
Building my car...
Pm me and we can talk.....This is something we sell for Paul as a distributor.
Old Jun 1, 2008 | 08:29 PM
ErnieT's Avatar
Living life 9 seconds at a time
You have a tiny turbo. You'll never hit 600whp with it, no matter how much fuel you have. So run 4 1000cc inj. and you'll still have more than you need. Trust me, Im speaking off experience.
Old Jun 1, 2008 | 09:08 PM
glenrx7's Avatar
Building my car...
ErnieT, you are the man, however the goal is not to run 620 but have the fuel for it....thanks man your advice is always welcome.
Old Jun 1, 2008 | 09:17 PM
ErnieT's Avatar
You lost me. Why run all that injector if your only going to hit say...500ish? Isn't that a waste?
Old Jun 1, 2008 | 10:07 PM
glenrx7's Avatar
Building my car...
Having extra fuel is something I like if you can still idle well. The fact is if we were shooting for 400 I would use 780 and 4 1000cc injectors, but we are shooting for 550hp. And yes it can be done, Jrat is making over 500 on a s5 engine with a lot less porting, and it is the same t67(to4r)...
Old Jun 1, 2008 | 10:09 PM
ErnieT's Avatar
Cool, good luck. Bridge it!
Old Jun 1, 2008 | 10:28 PM
Viking War Hammer's Avatar
*** Bless The USA
Glen, I haven't forgot about you !!!!!!!
