Help me ID this carb.
Old May 31, 2008 | 05:47 PM
blackdbl0si's Avatar
I was told it was a Webber 44 something. The only 44's I can find any info on are the 44 IDF. Yes? No? You guys have been a big help before. Thanks in advance.
Just before I got her back on the road.
Old May 31, 2008 | 07:29 PM
hooks rotary's Avatar
carb
that looks to be a 48 idf ,but it maybe a 44 ..... It should be stamped on the bottom ...
Old Jun 2, 2008 | 10:32 PM
trochoid's Avatar
Old Fart Young at Heart
Since it has the old Rotary Engineering intake, it's more than likely the Weber 48 mm IDF. RE didn't offer a 44 mm version. If you look down the carb throat, you should see 2 raised cast numbers designating the venturi size. 48 mm would be the maximum venturi size that can be installed.
Setup looks to be in excellant condition, hang on to it.
Old Jun 3, 2008 | 12:15 AM
DriveFast7's Avatar
Blood, Sweat and Rotors
That looks like a RE Weber IDF carb. It has a choke. If you clean off the outside of the carb with carb cleaner you'll see the stampings on the body which will answer the question.
Old Jun 4, 2008 | 08:06 AM
Thank you guys, I'll take a look when I get a chance.
heywier427
Naturally Aspirated Performance Forum
Sep 11, 2015 04:49 PM
ScruffyChimp
Apr 11, 2002 12:18 PM
