FC with Ksports on
Old May 30, 2008 | 11:28 AM
Digi7ech's Avatar
I break Diff mounts
FC with Ksports on
Just installed my Ksports. I did a quick photo shoot. Didn't even bother washing the car.
Ride height up front is the max setting and I had to trim the inner liner to get room. I'm running 235/45/17's all around on a 8 inch wheel.
Before
After
Old May 30, 2008 | 11:46 AM
87 t-66's Avatar
not a drifter
looks nice, where are the center caps for your wheels? looks like you could use a spacer for the rears
Old May 30, 2008 | 11:56 AM
Digi7ech's Avatar
I break Diff mounts
never had the center caps. I kind of like the bare look anyway.
I use to have a 5mm spacer up front but had to remove it to get wheel clearance. I may put it in the back to help make it flush.
Old May 30, 2008 | 02:18 PM
Groshuk's Avatar
have you driven it much yet? I just ordered K-Sports so I am curious
Old May 30, 2008 | 02:52 PM
Digi7ech's Avatar
I break Diff mounts
went drifting a little last night.
Felt pretty good. The rear end seems a bit easier to step out.
I just got manual steering so keeping hold of the steering wheel has gotten harder. It wants to straighten itself out. Still gotta get use to it.
Old May 30, 2008 | 04:17 PM
Flash's Avatar
re-amemiya body vert
How is it riding over bumps at speed being that low? Ever hit the bump stops? What spring rates did you get (or did the come with)?
Old May 30, 2008 | 04:52 PM
CarzArKoo1's Avatar
looks great! no rub issue in the front when turn?
Old May 30, 2008 | 04:53 PM
Digi7ech's Avatar
I break Diff mounts
These are the Kontrol Pro's.
They came with 10.5's and 11's.
No bump stops. I have scraped the bottom of my exhaust in deep ruts. The exhaust is about 1 1/2 inches off the ground so it's the first thing to hit. Not all the time though. I think I found a decent ride height.
The bumps are pretty livable. I did hit a 1-2inch ledge/drop on a bridge and got scared for a sec but never lost control.
No front wheel rubbing as of now. I trimmed the top off of the inner fender liners and removed my 5mm spacer on the wheel which I think puts it to a 35mm offset.
Old May 30, 2008 | 05:23 PM
namelesspenguin's Avatar
chasing those red numbers
looks good.
makes me wanna get some.
Old May 30, 2008 | 05:28 PM
Zenki FC3S's Avatar
\\TRASHTALK//
damn, i can get the pics on either site... see you out this weekend?
Old May 30, 2008 | 06:15 PM
siscu's Avatar
very beatiful set up man...
a question about the 5mm spacer... what ET are you running?
because i´m running +38 with 8" wide with 225 tyre and my stock shocks hit the tyre wall, i mean that, if i run coilovers is it possible to remove the spacers?
Old May 30, 2008 | 08:34 PM
Digi7ech's Avatar
I break Diff mounts
was running stock springs and tokico struts before this setup.
The wheels with a 5mm spacer would clear the spring by 5mm. I had no rubbing on the fender liners/etc.
235/45/17
The coilovers have a compact spring so you can get more tire under there closer to the strut without touching the spring.
Old May 30, 2008 | 08:46 PM
88rxn/a's Avatar
tom port.. AKA streetport
looks good. i whish i could save up that kind of cash.....maybe i should!@
Old May 30, 2008 | 11:24 PM
K!NCH's Avatar
Looks really good, I'm thinkin of getting KSPORTs too.
Old May 31, 2008 | 04:45 AM
LeeTheSlacker's Avatar
you need shorter tires, pronto.
other then that, nice height.
which ksports did you get?
Old May 31, 2008 | 08:17 AM
drunknmunky's Avatar
Black and bronze, always looks good.
Old May 31, 2008 | 09:44 AM
RX-7tII88's Avatar
Do Work
Looks like you have a different front bumper in the second pic..
Looks really good!
Old May 31, 2008 | 09:53 AM
willub and company's Avatar
Pobody's Nerfect
damn that looks really nice, completely changes the look of the car.
Old May 31, 2008 | 01:44 PM
Digi7ech's Avatar
I break Diff mounts
I was running the AIT front bumper but it was getting too fucked up. I know it would get destroyed running it with these coilovers. This is my drift/track car. So cones and front end damage are most likely going to happen.
I may switch to some type of front lip.
The coilo overs were Kontrol Pro's
