15 X 7 Wheels For FB
Old May 26, 2008 | 06:43 AM
YBNormal's Avatar
RI 15 X 7 Wheels For FB
Hi. New here.
I have an '84 GSL-SE which I hope to use in Vintage Racing at some point, after I have completed some much needed maintenance. In reviewing the rules for vintage events, it seems that an increase of 1" over stock wheel diameter is the most permitted. But it seems there are not many choices of 15X7 wheels that fit the 84's 4X110mm bolt spacing.
Any thoughts/suggestions?
Anyone got wheels for sale that would serve my purpose?
Thanks.
Old May 27, 2008 | 12:50 PM
j9fd3s's Avatar
Community Builder
panasports! vintage racing?
Old May 30, 2008 | 09:36 PM
eprx799's Avatar
you don't have 4x110 wheels on your car if your an se you have 4x114.3 .
4x110 is every other sa/fb bolt pattern.
there are many more options in 4x114 size I use to run 4 lug fc wheels on my gsl-se . I now use panasports light and they look right.
Old May 30, 2008 | 10:09 PM
Jaime Enriquez's Avatar
OLDROTA
As eprx said...you have the 4x114.3 pattern....you have a WIDE range of choices...just offset is +38 to +40 range....unlike the +20 offset of 4x110 versions. Many used rims available too!
Alothough....my buddy with an SE has SSR mesh with a pretty low offset (+15 I believe) without clearance probs...make sure you run a 195 tire in the front with low offsets, his 205's rub a tiny bit.
FB_Frank85
Sep 6, 2015 11:29 AM
