90 n/a. rpm break up around 3grand and higher
1990 n/a fc. rpm break up at 3grand. the code comes on 20minutes after running. engine codes i got were
01 trailing ignition coil malfunction of spark plug, broken wire, short circuit Trailing side ignitions pulse cut .
08 airflow meter (AFM) broken wire, short circuit basic fuel injection amount and fixed timing .
these are the only 2 codes that matter.
all the reset are emmision and omp cause there all gone. i replaced the trailing coil pack,air mas sensor, air flow meter, injector relay, all these parts work. reset the battery everytime i changed a part. still comes on after 20 mins. before the light comes on the car runs 100%. if i turn the car off while the check engine is on. and turn it back on the code dissapers for 20 mins. im going crazy to figure out this problem. tps is good. any sugestions are helpful. thank john.
it seems like the spark is breaking up. plugs are good and are the wires
Is the problem frequent? or just all the time?
I had an 89 GTU that wouldnt go over 3k alot, i swapped my TPS sensor and my ECU just to see if it would do anything and it fixed my problem. But im not sayign go out and change them. If you have a buddy with the same ECU, swap them and see if anythign changes.
One day a girl brings home her boyfriend and tells her father she wants to marry him. After talking to him for a while, he tells his daughter she can't do it because he's her half brother. The same problem happens again four more times! The girl starts to get pissed off. She goes to her mom and says, "Mom... What have you been doing all your life? Dad's been going around laying every maiden in the town and now I can't marry any of the five guys I like because they have turned out to be my half brothers!!!"Her mom replies, "Don't worry darling, you can marry any one of them you want, he isn't really your dad."----------------------------------Do you look for free wow gold? Welcome to our WoW gold website:1.WoW gold,2.WoW gold,
rgordon1979
40
Mar 15, 2022 12:04 PM
The1Sun
Sep 18, 2015 07:13 PM
The1Sun
Sep 15, 2015 04:45 PM
