Rotor / rotor housing cleaning
Old May 20, 2008 | 04:53 AM
boiprojectrx7's Avatar
what the best way to clean all the carbon on it?
Old May 20, 2008 | 07:50 AM
Rocking Rotary's Avatar
wire brush, scotch bright pad, razor, carb clean, and lots of elbow grease.
Old May 20, 2008 | 10:21 AM
fendamonky's Avatar
F'n Newbie...
Is your engine broken down, or in the car and running???
If your not in the middle of a rebuild than I would say injecting distilled water direction into the running engine would be best. Here is a link that explains the why and how (I did it to mine with no ill effects).
http://www.rotaryresurrection.com/3r...injection.html
Old May 20, 2008 | 10:28 AM
IRPerformance's Avatar
Sponsor
DO NOT use a wire brush or anything abravise on the inside surface of the rotor housing where the apex seals ride. If you don't have access to an ultrasonic parts washer, soaking in gasoline or Mac's carb cleaner overnight and scrubbing with a nylon brush works pretty well. Buy one of those big plastic storage bins with the lid at Target or Walmart and fill it with the fluid. Make sure you wear proper skin and breathing protection and their is adequate ventilation. You can use the wire brush on the sides of the housing. I even use a 3M fine abrasive impregnated sanding wheel if the housing is especially dirty. The long Moroso engine cleaning brushes available from Summit Racing work well to clean the coolant passages.
Old May 20, 2008 | 09:45 PM
silverflash2's Avatar
Mineral spirits
cristoDathird
28
May 30, 2019 08:47 PM
cdn
14
Sep 10, 2015 06:23 AM
cdn
2nd Generation Non-Technical and pictures
Aug 11, 2015 08:59 PM
