another problem someone help quick please
Old Apr 30, 2002 | 02:23 PM
MazdaRx7Power's Avatar
i thought i was having a coil problem, so i got another one for $50 but the car still didnt start. rpm's started to move and then just drop and dont move again. is it possible to have a bad ground on the coil also how can i ground it?????
Old Apr 30, 2002 | 02:28 PM
HN's Avatar
HN
more specific's please
Old Apr 30, 2002 | 02:30 PM
well the car doesnt start thats about it. tested the spark with a spark plug test and bottom ones dont spark. changed the coil and it still doesnt spark.............
Old Apr 30, 2002 | 02:32 PM
HN's Avatar
HN
do you have voltage at the coil pack?
Old Apr 30, 2002 | 02:42 PM
i tested it with a spark tester and the bottom ones dont spark.... what wire can i ground to see if its a bad ground or where can i add another ground just to be sure...
Old Apr 30, 2002 | 03:04 PM
anyone..................
Old Apr 30, 2002 | 03:11 PM
HN's Avatar
HN
if you look at the coil pack you will see a plus and a minus under the plastic cap. do you have 12 volts there?
Old Apr 30, 2002 | 03:45 PM
i checked it with the key turned on and it shows .02
Old Apr 30, 2002 | 07:38 PM
HAILERS's Avatar
HAILERS
The LEAD coil assy has a small white electrical plug going to it. Turn the key to ON. Get a meter and put it on the Black wire with a yellow stripe. You should have 12v there. If you don't you probably have a blown fuse, either in the crew compartment or the fuse box in the engine bay. In the crew compartment, next to your left ankle there is a fuse box. Counting from the bottom row up , the forth row up and third fuse from your left as you look into the box, is the fuse that powers the ECU. That fuse gets its power from a fuse in the engine compartment. A sixty amp fuse I think. Just make sure all the fuses in that black box are good. Now the coil assy itself has to be grounded. It gets its ground from the mounting studs and nuts. If they are on, then there should not be a ground problem. Also there is a single bullet connector on that coil assy. Do not ever ground it. Someone on this site had one that was indeed grounded, preventing the coil from working.
Old Apr 30, 2002 | 09:22 PM
so i bought a new coil and the car still didnt start might be the igniter or a electrical problem... but i'm gonna take it to my mechanic if its cheap to fix i'm gonna tell him to just rebuild the engine with a streetport. told me $150 to streetport it so might as well get some more horses while i have the chance....
ZacMan
Sep 19, 2015 09:20 PM
The1Sun
Sep 18, 2015 07:13 PM
meetRoX7e
Sep 11, 2015 11:09 AM
