how do i get 500 hp?
Old May 19, 2008 | 05:18 PM
migsk8's Avatar
well anyways, i really want to do a ls1 swap, but i want to reach around 450 to 500 HP, NA, no nitrous, no superchargers, no turbos.........anyways, what are good ways to help me reach my goal of 500 HP with like, lets say..... $1000 to add on to the motor?
mods if im in the wrong section, just move the thread
Old May 19, 2008 | 05:47 PM
FelixIsGod29X's Avatar
Manual Rack
You will not even get close to those #'s staying n/a......good luck.
Old May 19, 2008 | 05:48 PM
whereiscarmensandiego's Avatar
build your self a time machine go into the future have a superior being build u a rotary motor come back and install it. then u can have 500hp n/a
but seriously for 1k i dont even think your gonna get a ls1 to make 500hp. your goals are too big for your wallet u need to open it up alittle more and add a turbo
Old May 19, 2008 | 06:26 PM
Josh18_2k's Avatar
try more like 3-4k if you're lucky. for <450.
Old May 19, 2008 | 06:47 PM
KaoticFdR1's Avatar
Be a Hero...Punch a Koala
i just googled "500 hp ls1" and went to AFR's article archive and here's a few
http://airflowresearch.com/articles/article083/A-P1.htm
http://airflowresearch.com/articles/article098/A-P1.htm
Old May 20, 2008 | 02:57 PM
migsk8's Avatar
i love how you just owned everybody above you, lol
Old May 20, 2008 | 04:58 PM
frijolee's Avatar
the implications matter
I'll call it ownage when you make the horses on the buget specified. You can barely buy the Fast 90 intake for the +$1k the OP mentioned, much less build a stroker motor...
Almost all stock displacement ls1s have an extremely hard time breaking 450 rwhp. Normal numbers for a heads/cam setup is closer to 420. That's still formidable but you need to be thinking 6.0L+ in an LSX if you want 500 honest horses at the back wheels.
Old May 21, 2008 | 07:54 PM
KaoticFdR1's Avatar
i wasn't trying to own anybody...just to show what it usually takes to get to that point
agreed
Old May 27, 2008 | 03:02 PM
ls1oo7's Avatar
build urself a lsx bowtie 454 .. im sure ull get more that ur 500.. use ur 1k to buy a nice fit to got out with ..
he never said how big of a ls1 .. lol ..
but in a stock 346ci
1k .. i see maybe cam and headers .. depending on cam say ms4 .. maybe 3770-380ish .. i dunno
and this is with u doing all the work urself.
just a question why no nitrous ?
trust me u will never need 500whp allllllll the time .
Old Jun 11, 2008 | 02:27 AM
JustinStrife's Avatar
Meth Head
there's no way you're going to add 210rwhp to an LS1 N/A for a grand. No way. Since you're already considering doing the money for the swap, focus on suspension, brakes, and tires to make the car go with the power better.
After you do all that, and get use to the power of a stock LS1, then start looking at a good cam, intake manifold, intake, headers, exhaust, ported heads, Ported Throttle Body, etc.
500rwhp is very attainable N/A with an Ls1, you're going to have to have a crazy *** Cam though.
Old Jun 11, 2008 | 10:19 AM
aaron1017's Avatar
Magic Triangles no more!
Just get a LS2. With Intake, Headers and Exhaust you will be right around 390-400rwhp.
Toss in a cam and get a tune.... and you should be able to get 450rwhp easy.
Old Jun 11, 2008 | 11:06 AM
Brismo7's Avatar
6 Speed FC
It will cost a little over 1k for a cam swap only. Well, to do it correctly it will.
You cant just throw in a cam and call it a day. You got to replace things while in there. For example, your definitely going to need to upgrade your vavle springs as a bare minimum requirement. And since your getting in there, you should replace the timing chain. and since you need to take off the oil pump to replace the timing chain, you should also upgrade to a ported Ls6 oil pump for cheap insurance. Then your going to need to replace all the seals (or atleast you should before other problems occur). Then your going to need a tune. which is either 200-500 at a dyno shop, or 800 for the software to DIY.
Cam swap is more than just a cam.
Old Jun 12, 2008 | 05:15 PM
KaoticFdR1's Avatar
Don't forget pushrods! lol
