WTF... can't remove fuel pump connector!!
Old May 12, 2008 | 03:40 PM
Wompa164's Avatar
Hi everyone,
Sorry for such a stupid thread, but I'm wrestling with my fuel pump harness connector and I CAN'T GET IT OFF FOR THE LIFE OF ME.
I don't know if the previous owner broke one of the clips or something but.. I don't see any clips to depress and I can't slide it off no matter how much I wiggle.
Does anyone have any advice? I feel like an idiot..
Old May 12, 2008 | 03:41 PM
JSmith0101's Avatar
Play Well
Pull harder.
Old May 12, 2008 | 03:50 PM
Wompa164's Avatar
Here's a shot of the connector and a bonus shot of the new fuel pump (Apex'i GTR33 Pump):
Attached Thumbnails WTF... can't remove fuel pump connector!!-fp_con.jpg   WTF... can't remove fuel pump connector!!-fp_pic.jpg
Old May 12, 2008 | 03:52 PM
j-specfd3s's Avatar
DONT PULL ON THE HARNESS!!!!!!!!!! YOU CAN PULL THE WIRES OUT! this happened on a juck car that i had... Mine was the same way when i was installing the walbro (learned from the juck car) i used a flathead driver and pried against it, came right out, after that slides in and out with no problem. Guess it was gunk or something and it just got stuck.
Old May 12, 2008 | 03:56 PM
j-specfd3s's Avatar
how much did you pay for that pump?
Old May 12, 2008 | 03:58 PM
Stanello's Avatar
backslash beanbagrace
Push in on the left side (going by the pic) of the connector and pull.
Old May 12, 2008 | 04:02 PM
j-specfd3s's Avatar
if tab is broken
Old May 12, 2008 | 05:43 PM
dgeesaman's Avatar
The latch is on the left side of the white connector. It can be a little hard to get it pushed in all the way. I've used a screwdriver to gently push the connector apart while using another tool to push in on the latch.
Dave
Old May 12, 2008 | 09:16 PM
Wompa164's Avatar
I got it, thanks a bunch everyone!
Now I've just gotta figure out how to mount the fuel pump on the tree..
Old May 17, 2008 | 03:30 PM
j-specfd3s's Avatar
Pretty much you are going for the same setup as the stock pump... Take your old pump off, place the pump/intake filter thru the bottom of the bracket and hose clamp it in, connect all tubes, wiring, etc. Button it all up and you should be good to go..
86glxNA
Aug 22, 2015 08:54 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
