is it ok to start car with no brake fluid?
Old Apr 29, 2002 | 08:44 PM
1bad7's Avatar
just as the topic states. theres no brake fluid in the system and the rear calipers are off the car. the clutch still has fluid though. does anyone know if starting the car will hurt anything? thanks
Old Apr 29, 2002 | 08:54 PM
redrotaryrock8's Avatar
i am not sure about this: but i know that the car has the same reservoir for brake fluid and clutch fluid. i dont know how that will affect things, cuz you need to disengage the clutch to start the car.
Old Apr 29, 2002 | 09:19 PM
1bad7's Avatar
yup yup, i know what u mean. the brake and clutch fluids are in the same reservoir but they have seperate compartments. this way you can drain either one without disturbing the other. the clutch fluid is still in there
Old Apr 29, 2002 | 09:45 PM
P'cola FD's Avatar
Hamado things my way!
I would not. The Master cylinder might get air in it and those are a bitch to bleed.
Old Apr 29, 2002 | 10:15 PM
paw140's Avatar
As long as you don't pump the brake pedal, starting the car shouldn't cause any problems. Not if pushing in the clutch will cause problems though, since they both have the same reservoir
Old Apr 30, 2002 | 07:02 AM
1bad7's Avatar
ok, thanks guys. guess ill wait till i put my calipers back on and fill it up
alphawolff
Nov 17, 2015 05:57 PM
josef 91 vert
23
Sep 3, 2015 11:20 AM
torky007
Aug 17, 2015 05:14 PM
Marty RE
Aug 13, 2015 11:19 AM
