my car can't start...
Old May 10, 2008 | 11:00 PM
steven_S.D's Avatar
Signal Drift Team
Exclamation my car can't start...
anybody can help me.. i'm driving 93' RX7.. yesterday i drive my car.. when i'm boost the car suddenly the engine got cracking noise,very loud cracking noise.. after that the engine misfiring,like no spark on plug then the engine die.. after that i try to start the engine but the engine can't on..
i ask mechanic what the problem then he said i could be compression leak.. coz i check the plug have spark n the fueling was okay.. but the engine can't start..
is it true the compression was leaking? or could be some other problem?
Old May 10, 2008 | 11:14 PM
Hitokiri_Gensai's Avatar
RHD ftw!
sounds like you blew an apex seal... was it running really rough after you heard the cracking noise?
Old May 11, 2008 | 12:57 AM
SLOASFK's Avatar
Top's always down
the cracking noise makes me think you spun a bearing, but it's more likely that you blew an apex seal. A compression test will reveal whether or not you blew one.
Old May 11, 2008 | 11:21 AM
steven_S.D's Avatar
Signal Drift Team
yup.. the engine is really rough after that.. when i press the clutch the rev just go down then the engine die.. after that i the engine won't start again..
Old May 11, 2008 | 11:23 AM
steven_S.D's Avatar
Signal Drift Team
well.. i'll try to test the compression then..
Old May 11, 2008 | 04:59 PM
Rollogic's Avatar
Sounds like a blown apex seal to me too. I had the same prob on my 7 which happened while I was boosting down the road. I could actually keep my car running, but had NO power and sounded like a single rotor motor.
Time for a ported 3mm apex seal rebuilt motor!
Old May 12, 2008 | 09:24 AM
steven_S.D's Avatar
Signal Drift Team
yeah.. i blown my apex seal.. i check my car already.. thanks for your help guys.. now i'm in progress to build that engine.. doing side port,single turbo conversion,front mount intercooler.. what ECU that good for RX7??
Old May 12, 2008 | 09:51 AM
Dudemaaanownsanrx7's Avatar
wannaspeed.com
alot of people including me like running the power fc with a datalogit/wideband.
Old May 12, 2008 | 10:41 AM
steven_S.D's Avatar
Signal Drift Team
hmm.. okay then.. maybe i use that power fc.. about turbo.. is it good if i using T04S?
Old May 12, 2008 | 12:27 PM
wannaspeed.com
What kind of power are you looking for? Street car or racing? A dual ball bearing turbo would flow alot and spool quicker like a gt35
Old May 12, 2008 | 01:09 PM
grimple1's Avatar
Turd Ferguson
gt3574 or a gt35r are my 2 best suggestions.
If you're going for more power, the ASpec 500R.
What's your goals and what's the car going to be used for is the best place to start? When you answer those, then you can select a turbo.
Old May 13, 2008 | 10:49 AM
steven_S.D's Avatar
Signal Drift Team
my goal is just around 350-370hp n for street use since i using my car for daily.. actually stock twin turbo setup if just boost up can set how high and can give how much HP? how much the price for GT35??
Old May 13, 2008 | 02:47 PM
Montego's Avatar
Don't worry be happy...
Top Answer: 1
use what whatever ECU your tuner has experience with.
Monsterbox
Jul 29, 2022 10:48 PM
astrum
24
Nov 15, 2017 08:44 AM
fastrx7man
33
Sep 2, 2015 09:42 PM
smikels
Aug 18, 2015 01:26 PM
