Leak or No leak?
Old May 9, 2008 | 03:12 PM
ahad's Avatar
Leak or No leak?
ok here goes...regular day started the car checked the oil n water as i always do..waited for the car to warm up as usual...leave the house go to this place 15mins away...temp late 20's early 30's i drove normally boosted only once...then abt 20mins later i start the car reach the end of the street, glance at the water temp and its 3/4th up towards H! kneejerk reaction i switch the car off while im on the road...manage to park on the side...pop the hood and i see water spewing outta the pipe thats connected to the radiator cap...pipe cut...anyway i change that and manage to get my hands on some water...fill the water and i notice that i fill it to the top but it keeps sinking in as if its leaking from somewhere...i look at the intercooler and i see water from UNDER it leaking profusely...i try to stick my head as far in as i can to see where the leak is but i cant cuz im stranded on the road...so i wait a min i fill the water up again start the car temps back to normal and i drive home without any probs...an hour later i check to see if theres any water leaking no leaks...i start the car i take it for a spin...boost around for a bit check the needle everythings normal i come home park it....took it out AGAIN after a couple o hours to set the boost temp was fine again everythings normal...
my question is WTF????
Old May 9, 2008 | 05:15 PM
SupraZed's Avatar
Sounds like you lost some water from the pipe when it was cut, the water under the intercooler was probably just water running down the cut pipe and the dropping below the intercooler.
If it's definitely not losing any more water then your ok, I wouldn't want to use normal tap water though, especially not in Pakistan
Most people won't even drink it, last time I drank tap water in Pindi it took me a few days to recover!
Anyway, make sure the pressure cap is ok, should say 0.9 on it, check the coolant level when cold which shouldn't be over the 'F' mark, then check it when hot, mine normally reads all the way up to the top mark, the check again when cool to see if it's reading at the 'F' mark again.
This will ensure that the system is properly sealed and that the vacuum pressure in the system is pulling the hot coolant from the overflow tank back into the radiator.
HTH
Old May 10, 2008 | 12:25 AM
ahad's Avatar
HTH
haha ur damn right abt drinking tap water man!thats a big no no im in islamabad im sure u mustve been there if u came to pindi...man i dont knw what this is i tell my friends driving an fd is like driving a new car everyday..why? cuz everyday theres a completely new prob hehe...i dunno if its the water from the cut pipe man cuz i found the cut i replaced the pipe THEN i put the water in but it was still coming down from the under the intercooler...that got me thinking if its the radiator pipe thats under the intercooler but if it was that pipe then why didnt my car heat up again or lose water could it be a case of the causing the pipes to get i dunno to get outta their place causing the water to leak...i dunno im jus thinkin outta my *** trying to think of a possible reason..thanks for the input!
Old May 12, 2008 | 12:18 PM
SupraZed's Avatar
Yeah, I was in Islamabad a couple of months ago, often went shopping in Jinnah Super, was surprised with some of the cars, even spotted a porsche Cayenne turbo.
I installed a greddy SMIC a few weeks ago and a few minutes after starting the car there was a pool of coolant dripping below the car, I crapped myself and immediately switched off.
After a few minutes of looking round I traced it to the upper radiator hose which must have got moved slightly. Even though the circlip was securing it the coolant was forcing it's way out when the pressure built up, I just moved it about a little untill it seated a bit better and all has been fine.
Just keep checking it after a drive to make sure the coolant level is good.
You must have the only FD in PK, is there anyone with rotary knowledge that you know of, I know there's a few RX-8's around so maybe that helps.
Old May 13, 2008 | 04:45 AM
ahad's Avatar
arite uve even got the names o the places down! nice :P as far as the cars go theres tons o fancy cars around in isb...got a phantom roaming around here too owned by some business tycoon. there arent a lot o fds in pakistan...theres only 2 in isb...another 2 in lahore,4-5 in karachi and a few in peshawar. but outta all o these fds theres only abt 4 of em runnin rotaries...everyone jus goes for a 1jz/2jz swap around ere...nobody knws how to work a rotary...the only way ive managed to make mine last this long is thanks to this forum...real life saver ...rx8s are just bought driven for abt 60k and trashed cuz they dont knw how to fix it...im jus gonna take the radiator out get it cleaned see if i can find anything wrong...neway cheers!
ls1swap
Jun 3, 2024 03:25 PM
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
LongDuck
Oct 7, 2015 08:12 PM
James Knox
Oct 5, 2015 07:56 AM
