Won't Start - 89 GTU
Old Apr 28, 2002 | 04:16 PM
SSearch's Avatar
Question Won't Start - 89 GTU
OK, I put in a new short block from Atkins rotary (great place BTW) for my friend. We roll the car out of the garage and it fires right up and drives great. He takes it out that night and it dies on him. I can't even get a sputter. I have spark, proper fuel pressure, and compression. All of the injectors register 13 Ohms resistance. I have taken apart the entire intake track, checked all of the vacuum lines and found no leaks. Please help, I have started to refer to it as the Demon car. Thanks in advance.
Old May 2, 2002 | 05:05 PM
SSearch's Avatar
Bump
Old May 3, 2002 | 12:00 PM
mazdaspeed7's Avatar
mad scientist
It turns over, right? It sounds like it flooded. A very common problem with rebuilds is they flood really easily until they are broken in. Rebuilds build compression for about the first 1000-1500 miles. Do the unflooding procedure, and then pour a few ounces of 2 stroke oil into the engine. Should fire right up, but it will smoke like a bitch.
Good luck.
Old May 4, 2002 | 10:52 AM
SSearch's Avatar
Thanks for the reply. I have tried pouring oil in the cylinders several times with no success. If I jumper the fuel pump circuit (yellow connection by the passenger strut tower) I effectively bypass the ACV and TPS, right?
To the best of my knowledge any engine will run, maybe not well, but will run if it has compression, spark, fuel and air. Please let me know of any other suggestions you might think of.
Thanks.
Old May 4, 2002 | 11:30 AM
drake696's Avatar
my friend had the same problem but with his comaro it turned out being a catalitic converter was cloged try checking that uther than that check ur timing other that that it's all i can think of
Old May 5, 2002 | 06:49 PM
SSearch's Avatar
It has a new exhaust system and Cat, but I will take it down to see if it is filled with fluid. Thanks.
Old May 7, 2002 | 07:43 PM
SSearch's Avatar
Bump
alphawolff
Nov 17, 2015 05:57 PM
1993fd3sracer1
29
Oct 13, 2015 01:57 PM
1993fd3sracer1
20
Sep 7, 2015 11:50 AM
Im faster
Aug 19, 2015 02:57 PM
