Sponsored by: CARiD
Starting Problems... ECU?
Old Apr 25, 2008 | 07:15 PM
91' RX-7 Vert's Avatar
Ok my car will start, run for a 1/2 sec at 3k RPMS then it just dies like its life plug was pulled out i checked the ECU or ECM the same thing and has a couple of black burn points at places is this the problem?
Old Apr 26, 2008 | 04:21 PM
WTF? no help?
Old Apr 26, 2008 | 06:49 PM
RotaryBred's Avatar
Lost You in the Rear View
sounds like a fuel starvation problem to me. could be a number of things. do you have a fuel pressure gauge? have someone start it while u watch the pressure. i bet it drops as soon as the engine starts. obviously low pressure means bad pump or filter. hopefully thats all it is. otherwise.. like i said it could be a number of things
jay85gs's Avatar
4x110 SUCKS!
You could find someone that has a compatible ecu and ask them if they can loan it too you. Swap them and see if this helps. Also could be something as simple as a fuel filter clogging or a fuel pump on the fritz..................
Old Apr 26, 2008 | 07:14 PM
ok... it is fuel starvation i added fuel to the air filter and it would stay running but as soon as i stop it dies, ok it didnt start doing it till i seen black marks or ECU, but i did notice when i take out the middle plug it would run erratic but would run for about 15sec instead of 5 sec
Old Apr 26, 2008 | 07:34 PM
jay85gs's Avatar
4x110 SUCKS!
If I were you, I would not push the issue, do not try and make your car run by adding gas to the air filter(a car fire is not something you want). Leave the car alone until you find another ecu. Swap the ecu and see if the car starts and runs on it's own. If you are still having issues after that then check your injectors. Good luck to you.
Old Apr 26, 2008 | 07:49 PM
well seeing as its my only vehicle and it will be close to a week b4 my part gets here, im in dire need, anyone near Siler City, NC with one of these would be nice
Old Apr 26, 2008 | 08:32 PM
TTT... any more Help???
Old Apr 26, 2008 | 08:37 PM
Rx-7Doctor's Avatar
You need to perform a fuel pressure/volume test.
First check and see if you can hear the fuel pump. Near the oil filter there is a wire harness with a yellow 2 pin connector. Bridge the connectors with a piece of wire then turn the ignition to the on position (not start). Go to the back of the car and see if you can hear the fuel pump making a whirring noise. Might just open the hatch and lift up the rear carpet where the fuel pump is.
If you cannot hear the pump then check the EGI main fuse.
Old Apr 28, 2008 | 04:34 PM
ok... does anyone have a pic of this thingy my RX7 manual isnt helping me out too much...
Old Apr 28, 2008 | 05:23 PM
bumpy bump
Old Apr 30, 2008 | 03:35 PM
TTT... I need some helps
Old May 2, 2008 | 04:53 PM
Dude I dont see the 2 pin connector
Old May 2, 2008 | 04:54 PM
Bump bump... Keep this open people
Skeese
65
Mar 28, 2017 03:30 PM
Microtech
30
Apr 23, 2016 06:37 PM
1993fd3sracer1
29
Oct 13, 2015 01:57 PM
1993fd3sracer1
20
Sep 7, 2015 11:50 AM
