T2 Swap Results Info
Old Apr 22, 2008 | 01:20 PM
hkspwr_rx7's Avatar
okay......i just barely got my t2 motor shipped in and whats the max boost i could go on a stock turbo for both drag and drift and what is the results if i ran a 3 inch downpipe and 3 inch straight pipe (no cat or resonator...just straight) to a hks hi power or a apexi n1 exti???
Old Apr 22, 2008 | 02:51 PM
coxxoc's Avatar
Shooting for 500
I ran 12 psi for some time on a stock turbo before it started blowing smoke like crazy. I'd say 10 lbs and below is plenty safe. You can do 12 lbs but it will wear out pretty quickly. I turned it up over 12 but got no power increase.
BTW by turning up the boost, you will need some sort of timing/fuel management. You will also need to port the wastegate on the turbo to prevent a lot of boost creep.
Old Apr 22, 2008 | 11:29 PM
RotaryRocket88's Avatar
Top Down, Boost Up
1. Port wastegate
2. Buy 720cc secondaries
3. Buy Rtek 1.7 or other fuel controller
4. Buy Walbro 255 or FD fuel pump & rewire
Don't run 10+ PSI on stock injectors and fuel pump. It'll be fast and fun for awhile, but you'll end up with a blown engine eventually.
Old Apr 22, 2008 | 11:31 PM
fastrotaries's Avatar
W. TX chirpin Monkey
S4 or S5 motor....compression test before you start cranking it up.
Old Apr 23, 2008 | 01:10 PM
hkspwr_rx7's Avatar
wait..whats the difference between the s4 and s5 and what year is which???i just bought the motor from an uncles shop...
Old Apr 23, 2008 | 01:14 PM
DRFTMSTR's Avatar
86-88 is s4 89-92 is s5
Old Apr 23, 2008 | 01:37 PM
rx-7 obsessed's Avatar
WTF is a Piston?..Anyone?
how many miles are on the motor?
Old Apr 23, 2008 | 01:46 PM
MazdaMike02's Avatar
Mazda Tech
I ran search psi on my search rx7.
Old Apr 24, 2008 | 04:55 PM
hkspwr_rx7's Avatar
ooo...its a s5 then....he told me it has 60k on it...but not sure
FD3S_wanted
Sep 22, 2015 06:18 PM
