Stock Top Intercooler Heat Shielding???
Old Apr 22, 2008 | 12:10 PM
ohayou88's Avatar
Is the stock top mount inter cooler suppose to have any kind of heat shielding on the bottom of it? If so I think mines is missing it. I'll have to check again later today.
If Im missing. I just stick some heat wrap on it. work out the same?
Old Apr 22, 2008 | 12:21 PM
Eple's Avatar
Epilepsy
Only heat shielding is on the top as far as I know.
I'm not 100% sure though, so don't rely on me.
Old Apr 22, 2008 | 12:38 PM
areexdrift's Avatar
Drift Heaven
there shouldn't be any heat shielding. the IC needs to be able to breathe extremely well. other-wise you'll just be forcing air into a plate and it wont charge the air properly... eventually leading to detonation.
Old Apr 22, 2008 | 02:32 PM
freemanrx7's Avatar
^Hold On
THere is a sheild underneath the interecooler. I think its more of an airflow setup rather then blocking heat. But It must block heat somewhat.
Old Apr 22, 2008 | 02:39 PM
evileagle's Avatar
Reverse Cerberus
There is a metal plate on the bottom of the intercooler, you might try covering the bottom of it with some heat reflective tape or something.
CaptainKRM
14
Aug 26, 2015 09:52 PM
04G35S
Aug 14, 2015 07:31 AM
