Anybody with a carter pump installed?
Old Apr 27, 2002 | 09:05 PM
BadAssRX-7's Avatar
The AUTO DOCTOR
well im wondering HOW you mounted it? got pics? im just wondering as im waiting on my stuff from summit to get here ...How will i mount it do i keep the stock pump shield...i wouldnt think so.. thanks guys
D.
Old Apr 27, 2002 | 09:09 PM
Directfreak's Avatar
I am a Jeeper Now.
Same question - with an Aeromotive 1000HP pump..
Old Apr 27, 2002 | 09:31 PM
stinkfist's Avatar
Learn to swim.
Whats up David?
I took that pump sheild off. I drilled three holes in the floorpan where the stock pump mounts and mounted the pump bracket there. You mount it side ways there. You could mount it farther up the axle arch if you want to mount it up right like the instructions say. I used the pump mounted on the side for 2 years with no problems.
We mounted it the same way on the race car and it has had no problems either.
You have to take the bin out behind the driver seat to screw the nuts onto the bolts but thats no big deal. It's real straight forward.
Mike thompson munted his using the pump sheild and it is loud as hell. It's loud anyway but his is even louder than most because it resonates off that sheild.
Later,
Mike
Old Apr 27, 2002 | 09:40 PM
BadAssRX-7's Avatar
The AUTO DOCTOR
go get me a pic mike hey you ditched the fb what did you do with the pump???
Old Apr 27, 2002 | 10:44 PM
hanman's Avatar
I mounted mine on the frame rail right before the rear axle. I mounted it vertically the way the instructions stated. I wish that I had of used some rubber spacers to reduce the noise level.
You will have to purchase a pressure regulator from Summit also. And you will need a pressure gauge, the only accurate one that I am aware of is from Paul Yaw for $45.00.
I mounted my regulator on the firewall by the hood latch. It required a 90 degree fitting to make it fit there.
hanman
Old Apr 27, 2002 | 11:03 PM
stinkfist's Avatar
Learn to swim.
I still have the Fb. It's just striped down to the hull and I'm building an ITA race car out of it.
I sold my engine because it was illegal for the class I'm racing and I sold the fuel system with it, along with the carb and my RB exhaust.
Later,
Mike
Old Apr 28, 2002 | 03:09 PM
riffraff's Avatar
smog nazi destroyer
i mounted mine in the same place as hamman.. just i welded the bracket on instead of drilling holes..
Th0m4s
Feb 26, 2019 02:04 AM
LMBTG
Sep 2, 2015 07:01 PM
12abridgeport
Aug 17, 2015 06:28 PM
gabescanlon
Interior / Exterior / Audio
Aug 11, 2015 05:59 PM
