post your premix methods
Old Apr 21, 2008 | 09:01 AM
driftingmyFC's Avatar
Rotary Turbo
I just decided to go premix and was wondering what are your methods.
All I understand is to go with premix thats for fuel injected motors and that I should do 1 oz per gallon of fuel. All I know is the reasons that I will go with premix.
If you can post what "brands", "where to buy", "best prices","premix ratio" will really help me out.
For those of you that go with the stock omp & are against premix please don't post your arguments here, there are other threads for that.
Old Apr 21, 2008 | 09:10 AM
manuelxj's Avatar
i run the Idemitsu (Premix) i order it from mazdatrix... ...i have a small contaner that i keep a premesured amount for a fillup in ..when i get to the gas station i dump the premix in to the tank then start pumping the gas...i like the idemitsu cuz it doesnt seem to smoke as much as the other stuff i was useing..
http://mazdatrix.com/q-supply.htm
Old Apr 21, 2008 | 09:29 AM
SpooledupRacing's Avatar
I buy the cheap tcw-3 walmart stuff I go to the gas station.. I get my funnel and add 1oz per expected gallon of gas I will fill..
I remove the funnel put the gas nozel in and fill to the gallonage I want (normally just under or just over depending on how much cash I have...
Old Apr 21, 2008 | 11:23 AM
eraser13bt's Avatar
I use the lucas oil premix with low ash, i get bulk for uber cheap. and i just do what the above person does with a 1;1 ration
My5ABaby's Avatar
Rotaries confuse me
I buy the cheap Wal-Mart **** and just pour it in the area where the cap is and let it drain into the tank through the little hole there.
Old Apr 21, 2008 | 11:33 AM
Spectator's Avatar
Cheap wal-mart **** here too.
As long as its TCW3, all is fine.
Spec.
Old Apr 21, 2008 | 02:10 PM
InsomniacFC's Avatar
Will drive for parts
Same here. I figure out how many gallons $40 will get me and then i round up to the next ounce (i.e. 7.7 gallons = 8 oz. or 7.7 oz if you're really **** about it). Put the premix in first and wash it down with gas. Some pumps will choke on it for the first gallon so keep an eye on it. After it all washes down you should be good.
Old Apr 21, 2008 | 02:47 PM
MaczPayne's Avatar
Mac Attack
Valvoline Multi-purpose TCW-3
I have a pump screwed on the top of the bottle that pumps approx. 1oz per stroke.
Quick, easy, and mess-free.
Old Apr 21, 2008 | 03:05 PM
Nick_d_TII's Avatar
I use Valvoline TCW-3 rated two stroke.
I usually put in about 10 oz of oil before they pump it... In oregon they pump the gas.
I pour from the bottle, and use an allen key to hold the little door open. I had a funnel, but left it at a gas station.
The price of premium gas, say 3.65 so I put in about $36.50 or $37 of gas = ~10 gal.
That is all. Funnels make it easier.
Old Apr 21, 2008 | 03:28 PM
texFCturboII's Avatar
version 2.0
pour in, using the "clear" window on the side of the bottle as a measure. Wipe excess. apply gasoline. enjoy.
Old Apr 21, 2008 | 04:50 PM
AlexG13B's Avatar
brap brap brap
went to walmart today and this is what i saw.
bluemunkey1820's Avatar
im going to use something like this
http://cgi.ebay.com/Brand-New-Manual...ayphotohosting
Old Apr 21, 2008 | 05:43 PM
HAILERS's Avatar
HAILERS
An old Acetone can with a windshield wiper motor installed in its bottom side with the outlet going to the vent line for the gas tank fill neck. No. No acetone in the can, just that WallMart stuff. Simple on/off toggle switch for the wiper pump. Toggle to ON and do a count of thirty, then Off. The gallon can is located in the rim area of the spare tire.
I still have the stock omp that works fine. I did this *can* thing just because I wanted to. Much like I used to have the stock OMP sucking two stroke oil out of a reservoir in the engine bay (not enough room for a decent size container imho, in the engine bay.
Old Apr 21, 2008 | 05:48 PM
a143gsxr's Avatar
I use Golden Spectro oil. You can get it anywhere dirt bikes are sold. Check ebay, sometimes you can find it cheaper there. I pay about 6 bucks for a 12oz. bottle. I have a little funnel/towel kit in the back to make it neat. I pour the bottle in and then put 9 gallons of gas in. The guys at racing beat use anywhere from 1oz. per gallon to 5oz's per gallon depending on the WHP and how often the motor is rebuilt. The 1oz. per gallon is good for most, but if you are making over 300whp add a little more. occasionally it's fine to run 1oz./per gallon or even a little less if you're in a pinch. the golden spectro is synthetic and in my opinion the best for the job. stephen.
Old Apr 22, 2008 | 09:09 AM
Rotary Turbo
Nice now, MORE please
13
Jan 9, 2018 11:19 AM
tonka_1956
Sep 2, 2015 05:55 PM
