all warning/dummy lights are on
Old Apr 20, 2008 | 10:04 AM
chnsx7's Avatar
hello, all the warning lights including the shift lgith on the cluster are on the whole time, anyone know what this could mean?
thanks,
Greg
Old Apr 20, 2008 | 01:16 PM
Nitrometano's Avatar
Do you feel lucky punk!!!
that sounds like electrical contacts problems. Check the connector at the wiring harness for corrosion and the connectors on the warning lights to be sure they are not loosed. Someone write something about resoldering the warning lights to resolve that problem. I know that I need to do that. I have intermitency problem with the clock and with the stop light.
Old Apr 20, 2008 | 01:21 PM
Old Apr 20, 2008 | 02:48 PM
HAILERS's Avatar
HAILERS
What year? Series four? Then the alternator is bad or the WHITE/black wire on the back of the alternator is shorted to gnd.
Old Apr 20, 2008 | 02:51 PM
87 t-66's Avatar
not a drifter
yep, alternator.
Old Apr 20, 2008 | 10:32 PM
chnsx7's Avatar
my alternator is brand new and i get 14 volts...
the clip tat goes on the back of the alternator is intact
Old Apr 21, 2008 | 09:53 AM
HAILERS's Avatar
HAILERS
Well the series car seems to be an unknown. Oh well.
Here's how a series four idiot light cluster works. Key is put to ON. The White/Black wire on the back of the alternator puts out a GROUND signal to a relay in the CPU. That relay pulls in because it already had 12v on the other side of it's coil. The contacts in the relay *make*. One wire of that set of contacts goes to gnd. The other goes to the idiot light cluster. Now you have put a gnd on the idiot light cluster and all the lights light up.
They lit up because the alternators white/black wire was putting out a gnd signal (alternator not turning over/putting out) or because the relay in the CPU is stuck in the closed positon, or because the wiring has been fiddle fucked with and a gnd is on the wire b/t the CPU and the idiot light cluster.,
Turn the key to ON. PUll the small plug off the alternator. The idiot lights should go off. If not, then the relay is bad or there is a short on the circuit b/t the CPU and the idiot light cluster.
Old Apr 22, 2008 | 07:01 PM
chnsx7's Avatar
yes mine is a series 4, i unplugged it, all the likes went off like normal. but now on eo fhte wires i forgot itf its the black or white one, is about to break off, i think that might be the problem?
Old Apr 22, 2008 | 11:15 PM
RotaryRocket88's Avatar
Top Down, Boost Up
Yeah, that's a major problem. Rewire it.
Old Apr 23, 2008 | 02:28 PM
HAILERS's Avatar
HAILERS
I'd like to suggest, that if you make a typing error, that you take the few minutes it takes, to go back and correct the typo. I'm not into puzzles nor rearranging letters in a sentence to figure out what was trying to be said.
What it gets down to, is this. IF your not motivated to make sense out of what you write, I'm not motivated to make sense of it.
JoesFC
Oct 5, 2015 08:10 AM
The1Sun
Sep 18, 2015 07:13 PM
The1Sun
Sep 15, 2015 04:45 PM
The1Sun
Sep 7, 2015 10:21 PM
