how to identify a t2 driveline?
Old Apr 19, 2008 | 07:05 PM
whereiscarmensandiego's Avatar
i think i might ahve a drive line because it dosent look the same as my s4 n/a drive line does . this is on my s5 gtu and i was wondering whats the easiest way to tell with the trans still mounted in the car. the most obviouse would be with the lsd but is there another way since it dosent run right now?
Old Apr 19, 2008 | 08:21 PM
Sideways7's Avatar
The NA tranny has a smooth case, while the TII is beefier and has ribs on it. If memory serves, it also has 2 drain plugs. The LSD is a different size, but its harder to tell.
Here is the full info: http://rotaryresurrection.com/2ndgen...in_differ.html
Old Apr 19, 2008 | 08:31 PM
does the clutches look different between the s4 and s5 i figured they were the same but the one i have looks way diff then my s4 and i know this one is stock
Old Apr 19, 2008 | 08:38 PM
MaczPayne's Avatar
Mac Attack
The flywheel should be larger if it's a Turbo. If you know the measurement of an n/a flywheel, measure the flywheel on your car and compare.
Old Apr 19, 2008 | 10:30 PM
misterstyx69's Avatar
Retired Moderator, RIP
215 and 225mm ..different size flywheels.My God "CARMEN"..you should know this By Now..you rebuilt a TII engine..Did you sleep through that?
Old Apr 19, 2008 | 10:31 PM
i was using a n/a driveline and i didnt pay atention to the act t2 flywheel i sold
George84
Sep 28, 2015 11:58 PM
pzr2
Sep 8, 2015 10:46 AM
Frox
Sep 8, 2015 08:36 AM
