Map Sensor question..
Old Apr 27, 2002 | 02:33 PM
WhiteRXseven's Avatar
Hey everyone..
How can you tell if your Map Sensor has gone bad or not? Does it make your car run a certain way?
are their andy tell tale signs of a bad map sensor??
Old Apr 27, 2002 | 04:32 PM
Hyperite's Avatar
Vagina Junction
You'll have bad idle, smoke, run real lean at idle, rich at throttle. You might've just knocked the hose off the sensor? otherwise, i don't remember how to test it.
~Tom
Old Apr 27, 2002 | 05:13 PM
GsrSol's Avatar
Z06 powered FD
You usually test them by volts at certain rpms an wot but I don't know how to do ours.
Old May 28, 2002 | 01:01 AM
Dan's Avatar
Dan
YEAH, ITS BAD. THIS IS THE SAME ******* ONE THAT YOU SOLD ME WITH THE AVC-R. THIS IS WHY IM HAVING SO MANY ******* PROBLEMS, IS'NT IT. THE CHECK ENGINE LIGHT COMES ON AND THE CAR RUNS LIKE ****.
ALSO WHEN I GET MY MID-PIPE ON AND THE ECU DONT MAKE A DIFFERNCE I WANT A FULL REFUND OR WE WILL END UP IN COURT............................................. .................
(FOR THE PEOPLE THAT DONT KNOW THE CAR DOES NOT RUN RIGHT WITH THE ECU HE SOLD ME) BUT I HOPE ITS BECAUSE IM RUNNING TO RICH...
SORRY TO VENT, BUT IM PISSED.......
Old May 28, 2002 | 01:10 AM
black99's Avatar
Lurking..................
Dan: Who ripped you off? If your CEL comes on do you know the error code? That error code should help you track down the source of your problem.
If you're map sensor is bad then your car will pretty much run like what it does when you disconnect the map sensor. Bad idle, lots of backfiring, lots of black smoke.
Old May 28, 2002 | 01:29 AM
Dan's Avatar
Dan
if I unplug it when its running it makes no difference
Old May 28, 2002 | 11:14 AM
Dan-
I am gonna only address you once and this is it.
I do not want to get into a pissing contest or verbal
arguement. No reason to act irrate and childish.I
seen your other post also. Slandering me and my reputation wont' do you any good.
1st of all:
You got a good deal you got a reprogrammed
RE AMEMIYA ECU And a Super AVC-R with instructions
and a map sensor SHPPED Under 600, which is a great deal.
2nd of all: I told you from the begginning that the ECU
was programmed for SMIC, DP, MP , CB.. Granted you have a DP and CB. nevertheless you would still need a intercooler and MP to have the ecu work efficiently.
Only problem you have is at idle when the fan kicks on
You even said, other than that everything worked great.
You get 14-15psi of boost and said car felt faster.
3rd: The Mapsensor: Reason I asked that question
initially because I couldn't get any PMS's PF piggy back
to work on my car becaues It would hit boost cut..
So that was my question regarding mapsensor
because someone said it could be the problem..
To let you know the map sensor I questioned about
is still in my CAR and works FINE.. The one I sold you
I bought off the forum, and works to.. I bought the Mapsensor from Silver93TT who is parting out his car to
go single turbo.. IT obviously worked when he had it, it worked for me.. For you to assume I gave you something bad is unjust and uncalled for..
4th: I read some of your post asking about the avcr and how you broke some nipples off some solenoids and etc.. Think maybe that could be the problem?? And for your information, your car would be running
off the MAP sensor off YOUR CAR thats already been
there from the begginning. Obviously you installed
something wrong. Just be patient and dont' take
your fustrations out on me.
5th: In good faith.. after you send me email
tellin gme the problems you are having..
You wanted me to buy back the ECU for 300.
I told you that I am strapped for cash, because
I was going to buy a haltec and midpipe. instead
I bought a PFC and midpipe..
SO I even offered to buy it back for 200.
Everything considering you are lucky I offered that.
I am doing what I can to help and do what I can.
But if you gonna act this way and slander me and
my reputation..I have no recourse for you.
take care
Old May 28, 2002 | 02:25 PM
Dan's Avatar
Dan
sorry sean, like I said I was venting "I was in a really bad mood. "No flames intended" every thing seemed to be going wrong. Nothing worked, its was the nicest day yet this spring, and my car was not running. Now im working out a few little bugs. I guess it woud help if I knew what I was doing! My mid-pipe should be here any day now, then I will put ur old ecu back in. like I said "sorry"
Old May 28, 2002 | 03:21 PM
No problem Dan.. Its all good..
BTW I installed my PFC and the Idle was screwy
Like bouncing also..
So today I installed my Midpipe. and Now walla..
The Idle and everything is smooth now.
And after taking off the Main Cat. I can see
why it would cause so much problems..
For 1 it weighs a good 40-50lbs.
IT was orginal cat, so after we dropped it to
the ground. stuff started falling out of it..
SO I assume its was clogged also..
On top of that. That THING Stays HOT.
I let it cool down for like 40 minutes, then
wrapped it up in a towel. put in my car..
Got back to work. The CAT was burning thru
my towel, still sizzling HOT after like a hour..
Wait and see, Your midpipe gonna cure alot
of your cars ills. the PFC was programmed
for midpipe, and with out it. car ran like crap.
with the cat out now. its smooth as a babies
bottom..
peace
Old May 28, 2002 | 03:45 PM
Dan's Avatar
Dan
Thats cool, you shootin flames now? Do you have any boost spikes? Cant wait to get mine. " hurry up mr. UPS man!!!
eddierotary
Engine Management Forum
16
Oct 4, 2016 08:22 PM
rotor_veux
Sep 19, 2015 07:13 PM
mulcryant
Sep 9, 2015 05:24 PM
befarrer
Sep 4, 2015 08:26 PM
