lean as hell??
Old Apr 16, 2008 | 07:59 PM
vato2000taco's Avatar
i hate donks!
lean as hell??
so my car had been running lean as hell(17.9 afr) from idle until 3500 then secs kick in and afrs are like high 10 low 11 so i thought it was my tps out of adjustment. So i checked voltage at tps and found out tps was bad so i replaced it. well it solved my hot start prob, but still lean as hell. now my check coolant level is on and ps doesnt work all the time. Any suggestions?
I heard that p/s and temp wrer tied in with tps and could cause problems
thanks, vato2000taco (rip toyota taco-ma)
Old Apr 17, 2008 | 01:57 AM
ecyrb | SLC's Avatar
Tokyo Drift Sellout
Clean your fuel-injectors...? TPS wouldn't have anything to do with starting (hot or cold), so you didn't fix your hot-start problem (if all you did was replace your TPS).
Another thing, you do know that the TPS is adjustable, right? Like, if you "check the voltage" and it's "wrong", you can adjust it... Do you mean it was out of spec?
Tip: Top off your coolant and power-steering fluid.
Old Apr 17, 2008 | 08:43 AM
Aaron Cake's Avatar
Engine, Not Motor
If your car is stock and your emissions system is working as designed, then those ratios are normal. The air pump is dumping air into the exhaust manifold to clean up unburned hydrocarbons (by burning them). All this air will make the sensor read lean.
Old Apr 17, 2008 | 10:24 AM
MmSadda's Avatar
Wow... are your primary injectors in OK shape? You should probably run some Techron (fuel injector cleaner) through it on a full tank of gas.
Also, look at Aaron Cake's post.
Old Apr 17, 2008 | 07:53 PM
i hate donks!
tps was non adjustable bc narrow voltage was .04 and didnt sweep with throttle
injectors worked fine when i pulled them out . i put them in a ziplock bag and installed new in box 780 primaries and it didnt work right so i put stockies back in and same thing
Last , I dont have any emissions on engine rats nest gone omp gone bac gone . I have t04b turbo rtek 1.7 , venom 1000 secs stock primaries venom 255 lph pump, tb modded, and e fan ooh yeah thermowax gone also
Old Apr 17, 2008 | 07:57 PM
i hate donks!
coolant is always full ,even when light ncomes on, no leaks. P/s leaks but immediately after i fill it up it will work intermitently and never stops whineing
Logan Reinisch
44
Sep 17, 2018 12:20 PM
Einheri
Oct 7, 2015 12:23 PM
93FD510
Oct 1, 2015 02:00 PM
WyomingTII
Sep 28, 2015 10:32 AM
