Microtech Red light on my ecu keeps blinking?
Old Apr 13, 2008 | 09:16 AM
Alex Rodriguez's Avatar
MODERATOR
Veteran: Marine Corp
My car starts fine and rive great , i havent boosted yet becasue i am still in the break in. It sometimes turns on and off for a few seconds then it shuts off
i dont have my air temp sensor hooked up , and my wastegate doesnt have a vacuum because i need to put a 90 degree fitting , but i cant boost anyways so its fine
What do you think could be the problem.
Old Apr 13, 2008 | 09:41 AM
hondahater's Avatar
spending too much money..
hook up a laptop and it will show you what the error is. More than likely it's the air temp sensor that you don't have connected
Old Apr 13, 2008 | 09:43 AM
AlexG13B's Avatar
brap brap brap
i would think the AI sensor not being hooked up can do that. cant find a connector?
Old Apr 13, 2008 | 09:59 AM
MODERATOR
no still i have the sensor but no plug , sucks i wish someone had one to sell
Old Apr 13, 2008 | 02:00 PM
MODERATOR
also ifn order for me to read my codes when i hook up the laptop to the adapter does it just pop up or do i need a software to download first
Old Apr 13, 2008 | 02:26 PM
hondahater's Avatar
http://www.microtechefi.com/software/setup.zip
Old Apr 13, 2008 | 06:54 PM
rx72c's Avatar
Top Answer: 1
When your microtech is on.
Plug your laptop in.
Connect to the ecu.
Press up once, then left, and youll see 4 status checks. Once you have checked them press left again.
Also if you have not got your air temp sensor connected it will spit out an error.
Old Apr 13, 2008 | 08:56 PM
MODERATOR
thanks guys i am going to subscribe to this thread for future refrence
