Microtech LT10s in FD for only fuel and ignition, and stock ecu for everything else?
Old Apr 11, 2008 | 09:54 AM
james81's Avatar
Hi guys,
I'm busy putting an LT10s in my FD and was wondering if anyone has any experience with wiring the LT10s to control only ignition and fueling, maybe boost too, and leaving the stock ECU to control the rest.
That way there is less chance of other ECU controlled things going wrong from the microtech, and there's less running through the microtech's brain too.
Feedback and criticism(constructive) will be appreciated.
Thanks,
James81
Old Apr 11, 2008 | 10:09 AM
FC3S_xceed's Avatar
what else runs through the stock ECU on FD's?
most everything like headlights and so on is not run through the ECU its a simple switch and wire circuit. (at least on the FC)
Old Apr 11, 2008 | 10:59 AM
willub and company's Avatar
Pobody's Nerfect
the entire emissions system for one.. i wouldn't bother though.
Old Apr 11, 2008 | 08:52 PM
rx72c's Avatar
Top Answer: 1
Yes its a good way to install a microtech in a fd. Other wise you will loose everything.
befarrer
Microtech
Aug 22, 2015 05:52 PM
