Pictures of my project... (warning 56k)
Old Apr 26, 2002 | 09:36 AM
rx7gslse's Avatar
EX Pres of DFW Drunks
ok, I borrowed a digital camera and took some shots of the Ground control stuff that's going onto my car here in the next few days. Enjoy!
Car in the garage
the new rear illuminas from behind
The new front spring perches & springs next to the old
Another shot of the new front stuff, look how short!
New rear springs:
Car in the air:
Shiny new camber caster plates to be installed:
Old Apr 26, 2002 | 09:55 AM
jeremy's Avatar
male stripper
nice, very nice. how much for the height adjustment?
Old Apr 26, 2002 | 10:08 AM
rx7gslse's Avatar
the coil-overs were ~$100 from Ground control.
The jackstands were $20 from Sears
Old Apr 26, 2002 | 10:09 AM
1st7heaven's Avatar
Looks good. I have a similar set up. I have finished pics. here at work if you would like to see.
Old Apr 26, 2002 | 10:18 AM
1st7heaven's Avatar
Those springs look awfully familliar, who is this?
Old Apr 26, 2002 | 10:25 AM
rx7gslse's Avatar
That's because they came from your garage last night
Hi Steve!
Old Apr 26, 2002 | 10:28 AM
jmseven's Avatar
Asset is Wealth
the springs are by Eibach.
Nice setup....Those camber plates are really nice. I see they went to anodized purple.
1st7heaven's Avatar
Thought I would take your advice and check out this forum....THANKS for the info! Let me know how the springs work! You better get to work, jobs are thin out there....hahaha. PS how can I get my own icon under my name?
Old Apr 26, 2002 | 10:41 AM
jeremy's Avatar
male stripper
watching the car fall sideways off the scissor jack in your gravel driveway........priceless.
the full coilovers where 100? is that front and rear or is that front springs with height adjustment?
peejay's Avatar
Old [Sch|F]ool
Okay... 8" springs... I'm guessing 300-350lb/in?
I think I can reverse engineer that kit Everything except for the shocks. Maybe use 200lb-in 10" springs
Old Apr 26, 2002 | 10:43 AM
jeremy's Avatar
male stripper
you have to clear 300 posts i believe for a custom avatar. anybody? 300 right?
Old Apr 26, 2002 | 10:49 AM
rx7gslse's Avatar
I'm pretty sure it's just 100 posts.
The $100 was just for the threaded spring perches. The whole kit cost more than that..
It's basically everything from this page:
http://www.ground-control.com/gcrx7cat.htm
The rate for the fronts are 350#, the struts for the front are actually off an Mr2 I beleive(part #BZ1086). They are supposed to work better for high spring rates than the normal Illuminas for 1st gens (good up to about 300#)
We're not sure what rate the rears are. anyone know how to decode GC's numbering scheme?
Old Apr 26, 2002 | 10:56 AM
peejay's Avatar
Old [Sch|F]ool
Give me the number off of the spring
BTW - you can get coilover conversion kits for $40 a pair from most roundy-round suppliers, and springs for $30 or so each for 2.5x8" springs, any rate you want. I can duplicate that for $100 in parts
Old Apr 26, 2002 | 11:03 AM
rx7gslse's Avatar
live and learn I suppose..
I'll pull the numbers off the spring at lunch.
Old Apr 26, 2002 | 11:04 AM
jeremy's Avatar
male stripper
afco has a lot of this type stuff for little $$$ and you can choose all of your rates etc. i don't think they'll have that aluminum hat though.
Old Apr 26, 2002 | 11:05 AM
peejay's Avatar
Old [Sch|F]ool
The hard part will be making the seat that the threaded collar slides onto and keeps the whole thing centered... that's probably worth the additional $60 No need for that if one's willing to do a bit of cutting and welding though...
Old Apr 26, 2002 | 11:08 AM
peejay's Avatar
Old [Sch|F]ool
You mean the camber/caster plate?
Heck just make your own... everyone has a milling machine right?
Old Apr 26, 2002 | 11:14 AM
rx7gslse's Avatar
actually, these require cutting and welding too. The stock spring perch will be hacked off, and if you look at the second picture, you can see a steel collar and doghnut looking piece. Those will be welded onto the housing at the 6.5" point on the tape measure.
Then I want to paint it all all about the same red as the springs.
Old Apr 26, 2002 | 11:18 AM
peejay's Avatar
Old [Sch|F]ool
Okay, Plan B - I'll use some spare Honda Accord springs I have laying around, and measure some Scirocco performance struts I have laying around to see if they'll fit in the RX-7 strut housing
I just gots all SORTS of parts around here...
error402's Avatar
#!/sup_mod/üb3rg33k
wow looks good. i don't see to many GSL-SE's that are black. Are they uncommon?
Old Apr 26, 2002 | 11:22 AM
1st7heaven's Avatar
finished set-up
my F-prepared 1st gen. front end
Old Apr 26, 2002 | 11:40 AM
Max7's Avatar
Admitted Sevenaholic
me like me like very much
Old Apr 26, 2002 | 11:54 AM
jeremy's Avatar
male stripper
not the camber plate, the part on top of the spring in the front sus mod pic. but they don't have the camber plates either and i have no access to a milling machine, just a plasma torch set for 22-18 ga steel. guess i could cut a bunch and weld them all together.
Old Apr 26, 2002 | 12:35 PM
peejay's Avatar
Old [Sch|F]ool
The coilover kits come with the upper spring perch, too.
Old Apr 26, 2002 | 12:53 PM
1st7heaven's Avatar
camber plates
here is the top view
