why you DONT cut springs
On the fasttrack!
here are a few pics of the said victim
heres how the car sat with them on
and now with STOCK suspension
to put things into perspective, when i pushed down on the shock, there was 0 rebound, and the compression pretty much wasnt there, it took maybe 10 lbs of force to lower it.
see, this is why you dont cut springs. also, im going to have the alignment checked as well, its probably pretty off and looks like the bushings are shot, i know the tie arm bushings are......
DO NOT CUT SPRINGS, ITS NOT COOL, ITS BAD FOR THE SUSPENSION AND CAR!!!
oh, and the ride was SOOOO shitty. and i had my other car lowered correctly, illuminas on their stiffest setting WITH poly-urathane bushings and was a better ride quality then this ****.
idiots
peace
idiots
peace
On the fasttrack!
its running now, and i just got the halfshaft, so i should be able to move it by tomorrow. but running like my old one? idk about that. somethings up with the car.
peace
peace
Trending Topics
I cut my FB springs back in 1983 but only a little and they worked fine. Many do not realize that if you cut 1", the car will lower more than 1".
Spring style also affects the results. Those springs have a low coil count and varying diameter which makes them a poor canidate for cutting.
cutting springs is ghetto as hell and the car will ride ghetto as hell, and yes you will definatley need an alignment. i bet your toe angles are off by at least 1 to 1.5 degrees, say bye bye to your tires. if your toe angles dont kill'em, the sharp edge of the spring will when it falls out of place and digs into the sidewall
If you cut between 3/4 and 1.5 coils you will not have any problems and the ride will not significantly suffer. This is usually good for about a 1-1.5" drop. I don't go around doing it, but I have cut coils on more than one car in my life.
HEATING a coil is the really ghetto way. Cutting a small amount of coil off is no big deal, especially considering that in FC's the first coil on top is a dead coil just used for mounting. I found that 1.25 up front and 1.75-2 out back was ideal for FC's for a mild drop.
Hell, for that matter, I just put stock coils back on my rx8, and since the front on those cars sits higher than the rear, I cut 3/4 of a coil off the fronts to make it level.
The camber and alignment will not be off any more with cut coils than with lowerinc coils or coilovers dropped the same height.
true, ive just seen too many people come to my work after they cut the **** out of their springs w/ blown out side walls , tires that have 3000 miles on'em and are down to the chords on the inside edge, or the hideous sound of the spring binding up and clunking when you turn the wheel . cutting springs just instantly reminds me "Mexicans+'90 honda= WTF!?!?"
I had some racing springs, not sure which brand exactly, on my '83. It rode a little high for my liking I cut (appx.) 2.5 coils off all of them. The floorboards sat maybe 4" off the ground, and that was one of the best cornering cars Ive been in, even with the stock tires. My shocks were pretty dead, you certainly felt every bump in the road, but even at 130mph it handled like a dream. Im going to put those springs on my new 83, to compare them to my currant Eibach's
I think cutting any more than a few coils would be ridiculous. Your ride sucks because you only have like 3 full coils and its really sprung. Youll love the tokikos
my last fc had cut coils in the front, and even with factory shocks it was pretty good.
the rear was another story though, half length mystery springs, way too stiff way too short
On the fasttrack!
ya, i had my tokico illumina on tanabe sustec gf210's on my first rx7 that i totalled.
it rode like a dream, but right now im looking at jic coilovers.
and yes, it rode like ****, bump steer was scary (like trying to avoid deers at high speeds) and no, i didnt know cause i actually believed the previous owner (i REALLY shouldent do that)
peace
peace
Cutting springs *CAN* be a good way to lower a car or increase the spring rate, if done correctly. With wire diameter and coil diameter held constant, decreasing the number of coils increases the spring rate (rate of change is non linear).
Try this calculator, I know it is correct.
Shainiac
Jul 17, 2019 02:20 PM
