Midwest RX-7 Forum Serving KY, IN, IL, MO, MI, WI, IA, MN, ND, SD, NE, KS
Looking for some help in the Chicagoland area
Old Apr 7, 2008 | 10:21 AM
ranchan02's Avatar
IL Looking for some help in the Chicagoland area
Hi Everyone:
As the title states, I need a bit of help finishing up my FD. I messed with the TPS and now the car is idling high (3K) and wont drop down even when the engine is warm. Vacuum hoses seems fine. The only thing different is on the UIM I put 2 block off plates and messed with the TPS. I have a CEL code of 12 (Throttle sensor - full range) and I believe it has to be the TPS not being in the proper voltage range. Anyone local have any experience with dialing in the idle on an FD, any help would be appreciated.
Old Apr 7, 2008 | 10:59 AM
charlies7's Avatar
3rd rotors a charm
Joe ive done it a few times, along with everything else . If you need the help ill be back home from NIU this weekend.
BTW. Do you still have the old block from your car?
Old Apr 7, 2008 | 12:05 PM
ranchan02's Avatar
Hey Charlie, so your back for just the summer? Thanks for the help man I appreciate it. How does your schedule look for this coming Sunday?
As for the block, I decided to give it to Ryan (MoreMazda) as payment for helping me with the swap.
Old Apr 7, 2008 | 01:25 PM
impactwrench's Avatar
Cool
If you need the help ill be back home from NIU this weekend. I need my money
Old Apr 7, 2008 | 05:18 PM
charlies7's Avatar
3rd rotors a charm
This is true, ill send you a MO in the mail Dave your too far dammit..
Old Apr 8, 2008 | 09:16 PM
Railgun's Avatar
I won't let go
Veteran: Marine Corp
Why wouldn't you post this in the local forums as well?
Have you adjusted your TPS to get back into spec?
Old Apr 8, 2008 | 09:33 PM
Rotor13's Avatar
Originally Posted by ranchan02
Hi Everyone:
You can call this guy, he is the best Mazda Tech around chicago, he has my car going 7.82 at union grove. Can be seen at you tube, type in Mazda R100 and it is the first video. His name is Manolo # 773-526-8129. he has done a lot of these. good luck. Rotor13
Old Apr 9, 2008 | 09:30 AM
ranchan02's Avatar
If where talking about the same Manolo, the crazy rotorhead Puerto rican then I'm familiar with his work. Yes he knows how to build crazy fast rotaries . I think he's a bit far from my current location, nor do I want to drive the car in its current condition. Thanks for the reply back!
Old Apr 9, 2008 | 09:38 AM
ranchan02's Avatar
Hey Christian, whats going on buddy. I wanted to first post here since most people converge here first, but i'll def post on RC3 and see what kind of response I get.
Well, the main problem now is that my dad lovingly adjusted all the adjustment points on the TB (the 3 screw/nuts and that screw w/ the spring kinda behind the TPS) what happen is when you put on the TPS back to the housing (just to the point where you just have it attached) it keeps the butterflies (the ones w/ 2 butterflies) partially open and I'm not sure how to set it back to spec (the TB).
Old Apr 9, 2008 | 12:51 PM
Railgun's Avatar
I won't let go
Gotcha.
Being a visual kinda guy, I'd need to see it to figure it out. If worse comes to worse, I have an old TB that you have use if need be. It's still in stock form so if that helps at all with any deadlines you may have, lemme know.
Old Apr 9, 2008 | 05:04 PM
ranchan02's Avatar
Gotcha.
I'll probably take you on that offer. How much u looking for the TB? Also you work downtown right? Maybe we can meet up for lunch.
Logan Reinisch
44
Sep 17, 2018 12:20 PM
He's On Toroids
NE RX-7 Forum
48
Oct 19, 2015 08:58 PM
Rbkouki
V-8 Powered RX-7's
Sep 29, 2015 08:54 PM
