High beam + Low beam mod?
Old Apr 1, 2008 | 09:23 AM
Rookie84's Avatar
I swear I've seen a DIY on it but I can't find it... How do I wire up the high beams so that the low beams stay on when the highbeams are turned on? Thanks.
Old Apr 1, 2008 | 11:34 AM
2jz-13bking's Avatar
well im not sure bout haveing both high/low on same time thinking its going to be some kind of mod you have to do but you can always get a bi-xeon bulb.
Old Apr 1, 2008 | 03:55 PM
Smokey The Talon's Avatar
Long time on-looker
the stock setup uses one bulb to do both the high and low beams....it's not possible to run both at once.
Old Apr 2, 2008 | 03:04 PM
yea true,you can always get the RE-Amemiya sleek kit and rig them both up
Old Apr 3, 2008 | 03:03 AM
DK's Avatar
DK
40k worth of fail
It's a dual filament bulb, man. It can be done.
The bulb filaments share a common ground. Your light switch and low/high trigger control a 12V constant to one of the filaments at a time. There are a couple of different ways that you could do it using relays. The set up would probably have to be a bit elaborate to completely prevent overtaxing/melting the factory wiring. You also may face excess heat issues by running both filaments simultaneously, though you probably won't be using the high beams all that often. I guess I could think it through for you and tell you what to do if you really wanted.
Old Apr 3, 2008 | 07:32 AM
Long time on-looker
sorry, I merely should have said that on the stock setup it's not worth the wasted time and effort to put extra strain on an already weak wiring system and try to over run an outdated housing design to get minimally more light while your high beams are on.
Old Apr 3, 2008 | 01:20 PM
Rookie84's Avatar
I have RE HID sleek light kit... I should have mentioned that in the first place. Now, does anyone know how to wire this up? I'm really a noob at electrics so I need to know which wire goes to which...
Old May 15, 2011 | 11:39 AM
Max_Spd's Avatar
UA DRVN
Has anyone got a solution figured out for this, I know the thread is old, but i am trying to figure this out!!!
Old Jun 2, 2011 | 03:08 PM
Max_Spd's Avatar
UA DRVN
Just give you guys a heads up, I was able to make it work, with my HID kit, you simply connect the Headlight Relay driven signal White/Green wire with Low beam output Red/Yellow at the connector under the dash (center of steering wheel) Its a blue X-04 Connector...
I am using a dedicated FOG and 35watt HID kit so I dont have a problem with overloading the wire or blowing the fuse!!!
Old Jun 4, 2011 | 01:03 AM
Prôdigy2nd's Avatar
I
the pictures are down... but I remember finding this winter last year it explains what needs to be done...
basicly.. just have a wire connect the two main wires...
https://www.rx7club.com/showpost.php...&postcount=195
J.
Queppa
Nov 18, 2024 03:47 AM
msilvia
28
Apr 14, 2016 12:58 PM
eddierotary
Aug 16, 2015 04:12 PM
