Is there anything I could be missing?
Old Mar 31, 2008 | 06:42 PM
sm0keyii's Avatar
Everyone loves oppai =)
Question Is there anything I could be missing?
Ok, I'll start off by listing what I have, and what I still need to buy for my set up. I'm trying to make this rebuild swap/single conversion as smooth as possible. I will be doing this swap after I return from a upcomming deployment. The single set up will be made to run off of pump gas.
What I have:
-Rebuilt engine with new rotor housings and carbon steel apex seals and ceramic coated exhaust ports with plugs removed. Also has large street port.
-Apex'i PFC w/ commander
-Peakboost VMIC kit with modified Koyo rad and hoses for the set up
-used GReddy T-78 kit just missing oil feed line and some other part that Rotary Performance is helping me get.
-GReddy throttle elbow
-Apex'i AVC-R boost controller
-CJ motorsports fuel kit w/ pressure regulator
-CJ motorsports dual fuel pump holder
-two Bosch 044 pumps
-Exedy twin plate clutch kit and the bearings it didn't come with, and a counter weight
-Greddy type-R bov
-new alluminuml AST
-Apex'i turbo timer and harness
-RE Amemiya wheels 17x8.5F+42, 17x9.5R+42
What I still need to buy:
-Fuel pump relay (found out I needed it after a bit of research)
-new 550cc and 1600cc both topfeed
-emissions block off plates
-the stuff I listed above with GReddy turbo kit
-air pump removal pulley set
-custom piping from turbo to throttle elbow
-maintenance stuff; oil, plugs, wires, new water pump, fuel filter, gaskets, etc
What else is planned:
-Removal of all emissions
-Removal of A/C
I think that just about covers all of it. I know I'm gonna need some kind of differential upgrade in the future, would any reputable LSD suffice. I'm planning for a Cusco 1.5 or something of the like. So until i get the diff upgraded I'm not going to use my nice wide wheels. I'd rather burn rubber than shatter my pumpkin. Any suggestions about what else I may need to consider upgrading or replacing would be appreciated. I hope I provided enough info
The car in it's current state has just a GReddy intake (I'll sell it later), SS Auto Chrome DP (which held up quite well). RP resonated MP, and RE Amemiya exhaust.
Old Mar 31, 2008 | 07:36 PM
sm0keyii's Avatar
Oops, forgot to add boost gauge to the need to buy list (dee dee dee)
Old Mar 31, 2008 | 08:40 PM
jskyline's Avatar
ignition system like twin power
Old Mar 31, 2008 | 10:49 PM
sm0keyii's Avatar
Thanks *adds to list on desktop*
Old Apr 1, 2008 | 01:21 AM
EZFD's Avatar
Depending on how much boost you are planning to run, you may want to get some larger preimary injectors (750 or 850cc). Also a catch can. Other than that, everything else seems fine.
Old Apr 1, 2008 | 10:20 AM
sm0keyii's Avatar
What's the most you can get out of pump gas safely with the T-78? 15psi? Whatever the limit is, I plan run to run slightly under it for safety.
Old Apr 1, 2008 | 10:44 AM
Smitter's Avatar
94 Single Turbo FD
get a wide band
Old Apr 1, 2008 | 06:30 PM
EZFD's Avatar
Originally Posted by smitter113fd
get a wide band
Truth
Old Apr 2, 2008 | 07:18 AM
sm0keyii's Avatar
Thanks again all =)
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
Smokeyfb33
Old School and Other Rotary
Oct 1, 2015 12:10 PM
