NE RX-7 Forum Serving ME, NH, VT, MA, RI, CT, NY, NJ, DE, PA, OH, WV, MD and VA
OBD reader needed near Bel Air
Old Mar 31, 2008 | 08:03 AM
pugg57's Avatar
proper motoring
MD OBD reader needed near Bel Air
Any of you Bel Air local guys have an OBD reader and know how to clear codes? I got a code on my new car and well, everything points to me being an idiot and not tightening the gas cap properly, but I'd like to clear it out and see if it comes back on its own.
drop me a PM or something. thanks.
Old Mar 31, 2008 | 10:16 AM
Pele's Avatar
Right near Malloy
You can borrow them from Advance Auto, AutoZone, PepBoys etc...
Old Mar 31, 2008 | 10:30 AM
willub and company's Avatar
Pobody's Nerfect
yeah, most auto stores do a diagnosis for free.
Old Mar 31, 2008 | 03:01 PM
pugg57's Avatar
proper motoring
they read the code, but wouldn't clear it...
Old Mar 31, 2008 | 05:50 PM
Pele's Avatar
Right near Malloy
Correct the problem. 20 or 40 warmup cycles should do the trick.
Old Mar 31, 2008 | 08:45 PM
pugg57's Avatar
proper motoring
I did correct it, I think at least. I definitely re-tightened the gas cap, but the problem is, I only drive it once a week (if that). Didn't want to wait for 4-5 months for it to clear out on its own.
Old Apr 1, 2008 | 08:49 AM
Pele's Avatar
Right near Malloy
I have one, but for the drive down to VA, I'd think the fuel cost alone would be enough to buy a cheap one from harbor freight.
Old Apr 1, 2008 | 09:08 AM
pugg57's Avatar
proper motoring
looks like I may have access to one this weekend... definitely need to add this to my list of "stuff to buy"
Old Apr 1, 2008 | 10:16 AM
F1blueRx7's Avatar
Couldn't stay away
I'm selling mine for 75, I could meet you this weekend and get it to you, i've got family in bel air. It can read and clear.
Scanner: $75 Specs: http://store.summitracing.com/partde...art=sun-cp9135
Old Apr 2, 2008 | 01:21 PM
pugg57's Avatar
proper motoring
the specs at the link you sent me lists that it will only read up to a 2003 for my vehicle mfg. my car's an '06. i think that might be a problem... its weird because i thought all OBDII had to be the same code/read etc. but it lists up to 2005 for GM.
Old Apr 2, 2008 | 02:50 PM
F1blueRx7's Avatar
Couldn't stay away
what kinda car is it? If it's an 06 vette then you need something that can do CAN i believe... gotta double check that.
Edit... heres a better answer:
The C6 uses CAN (Controller Area Network) (which GM calls GMLAN) communications rather than the SAE PWM communications (which GM calls Class 2) at the OBD-II port. So you need a scanner that handles CAN. The AutoXray 4000 does, I know some other units that do but don't have a list handy. CAN is being phased in as the standard to replace the old mess of 4 or 5 different "standards", I think its required for 2008 but GM is getting started early with the newer models.
Edit, I dunno why I thought that... 2008 requires that all manufacturers convert over to CAN so chances are whatever your car is (you're being too vague...) is CAN already.
Old Apr 2, 2008 | 03:21 PM
pugg57's Avatar
proper motoring
Its pretty much null-and-void now anyays, as I find myself no longer needing to purchase one. I looked at the mfg specs for yours and it said 199?-2003 for Lotus. Thanks for the offer though.
befarrer
Microtech
Aug 22, 2015 05:52 PM
Machupicchu
Aug 17, 2015 08:27 PM
