Intake Manifold Port Matching
Old Mar 28, 2008 | 11:29 PM
13brenova's Avatar
Learns the hard way.....
I recently gasket matched my UIM to LIM and LIM to Engine. The mismatch on the UIM to LIM was very small, but the mismatch on the LIM primary ports to the engine was substantial. I've read a number of threads......it fights reversion......reversion is bad.....reversion is good. I realize it will be a minor improvement if any (Yeah, I'm bored while the car is getting painted). Bottom line, did I screw up the intake? The engine is a 13b-re, half-bridge, with a GT4088R turbo.
Old Mar 29, 2008 | 05:14 PM
13brenova's Avatar
Anyone?
Old Mar 31, 2008 | 07:44 AM
turbine's Avatar
do you have any pics of your work. port matching can increase flow which can increase HP. its a fine line though because you can also decrease flow and lower the charge velocity. which will lower HP. with out a flow bench you never know. but hey who has a flow bench. you are probably fine. but post up some pics
Old Mar 31, 2008 | 09:35 PM
13brenova's Avatar
Here ya go.........
Attached Thumbnails Intake Manifold Port Matching-lower-2-pre-port.jpg   Intake Manifold Port Matching-lower-2-post-port.jpg
Old Mar 31, 2008 | 09:37 PM
13brenova's Avatar
My mistake. There was a pretty big mismatch on the primary and secondary.
Old Apr 3, 2008 | 08:14 AM
turbine's Avatar
i think that looks fine. i plan on doing the same thing
Old Apr 3, 2008 | 01:28 PM
TweakGames's Avatar
FD pro licensed driver
Let me know how it turns out for you two, I am interested also.
BTW, where did you find a intake gasket for the RE?
Thanks
~Tweak
Old Apr 3, 2008 | 03:26 PM
Shainiac's Avatar
For some reason, on my 6-port, I remember the gasket matching up almost perfectly.
Am I wrong?
Old Apr 3, 2008 | 03:36 PM
13brenova's Avatar
Thanks
~Tweak
Mazdatrix
Old Feb 17, 2018 | 10:11 PM
speedjunkie's Avatar
Make an assessment...
Veteran: Air Force
Wrong thread.
Old Feb 21, 2018 | 09:21 PM
13btnos's Avatar
You didn't screw anything up what's more of a restriction is your stock manifold https://www.rotary-works.com/intake-.../RW-IM-COSMO-4 I'd look into this it will flow a whole lot better. I have the FD version but SemiPport haven't ran it yet but very nice piece. My buddy ran the stock cosmo intake with a Wilson 90mm throttle body and was making in excess of 1000rwhp so overcame the short comings of the stock manifold by just throwing more boost at it. Can't wait to see your car back up love it. Also I'd get a FD metal intake gasket and match it to the cosmo ports those paper gasket will blow out with higher boost pressures.
Old Feb 27, 2018 | 02:32 AM
RGHTBrainDesign's Avatar
Avoid that like the plague. I can think of 3 cars that had that intake manifold in the past, all leaked, and 2 of 3 caught fire multiple times.
C. Ludwig
Jan 30, 2019 06:31 AM
Engine stand ready
Aug 14, 2015 10:26 PM
