dyno results
Old Mar 28, 2008 | 09:52 AM
kovalev27's Avatar
dyno results
I just received a call from Magnus that my car is finally done and my car did 390 at the wheels, i was hoping more rwhp, tell me what you think?
1993 Rx7 R1
-Rebuilt, Street ported, 3mm apex seals done at Pettit
-Nippodenso fuel pump
-extreme fuel system from Rx7 Store
-T04S 60-1
-greddy elbow
-custom top mount intercooler
-4" turbo 2 back exhaust (no cat)
-tial B.O.V
-tial 44mm wastegate
-ACT clutch
-ACT flywheel
-spark plugs and wires
-unorthodox full pulley set
-AEM EMS
-ignition box
-windeband
-and little other suff
@17 psi
Old Mar 28, 2008 | 09:58 AM
rollingsband1's Avatar
i think it could do more also.. but then again im not familuar with tuning singles yet.. ive heard low 400's out of simular setups.. perhaps its a very safe tune?
Old Mar 28, 2008 | 10:50 AM
zenofspeed's Avatar
can you post the dyno sheet?
Old Mar 28, 2008 | 10:59 AM
kovalev27's Avatar
I will post it Sunday as soon as i get it
Old Mar 28, 2008 | 11:08 AM
1wide7's Avatar
most are in low 400s at 15psi what afr is this at power is definately down for the mods you have
Old Mar 28, 2008 | 11:15 AM
theorie's Avatar
AponOUT!?
seems low to me also...i would expect 400+ with that mod list.
Old Mar 28, 2008 | 11:45 AM
Jason's Avatar
The one
HP is a little low for that PSI. You should be around 420-430RWHP
Old Mar 29, 2008 | 06:40 PM
arghx's Avatar
rotorhead
What type of dyno? If it is a dynapack or Mustang dyno then it will read lower than a dynojet.
to know more we would need more details on the tune... how many degrees of advance and split, AFR curve, etc
Old Mar 29, 2008 | 11:42 PM
sk8world's Avatar
Chasing numbers
I have always heard Cam's streetports were done with a tooth brush, so to speak.. If in deed it is a "clean up" type port job that could hold you back a bit. Either way its not way off and could be the dyno readings. What hp were you wanting?
Old Mar 31, 2008 | 03:51 PM
kovalev27's Avatar
i was at least aiming for 420rwhp, i dunno how to make my pic smaller so check it out on myspace, my dyno sheet is there, and btw its a dynojet
http://viewmorepics.myspace.com/inde...7-30fc7760b22f
Old Apr 1, 2008 | 01:25 PM
HDP's Avatar
HDP
A Fistfull of Dollars!
message: "You Must Be Logged-In To Do That"
Old Apr 9, 2008 | 11:16 PM
bugman1973's Avatar
advanced novice
did you delete the pic or profile or something i get an error message
Old Apr 11, 2008 | 12:49 PM
kovalev27's Avatar
my pic is almost 700 kb and i cant put it on here coz its too big, anyone knows where i could post it?
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
Rotate86
May 18, 2018 02:44 PM
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
userjh5174
Alternative Fuels
Jan 9, 2016 08:49 AM
baix2
Power FC Forum
Sep 28, 2015 09:40 AM
