How much boost
Old Apr 24, 2002 | 10:44 PM
How much boost
i was wondering how much hp a stock motor with intake 3inch dp 3in mp greddy power extreme exhaust pulleys with air pump removed and a power fc
my car dynoed at 280hp to wheels no sign of detonaton the knock goes wway down when its boosting its high at idle
Old Apr 24, 2002 | 10:53 PM
P'cola FD's Avatar
Hamado things my way!
Your question is not very clear. Could you rephrase it. If not I'll have to put Samuel L. up here.
Old Apr 24, 2002 | 10:56 PM
i wanna know how much boost i can safely run on my motor on race gas with my mods
P'cola FD's Avatar
Sam Here he is.
Old Apr 24, 2002 | 10:58 PM
P'cola FD's Avatar
Without an upgraded intercooler I wouldn't go over 14psi if I were you . On my car I won't go over 12.5psi.
Old Apr 24, 2002 | 10:59 PM
ha ha funny
Old Apr 24, 2002 | 11:03 PM
mainly cause the intercooler is so shitty
Old Apr 24, 2002 | 11:05 PM
what can the motor handle with a good one
Old Apr 24, 2002 | 11:20 PM
P'cola FD's Avatar
Without upgraded injectors I still wouldn't go over 14psi, but with better injectors you can easily push 18psi. Not on the stock turbos, though, they blow goats. Even at 14 they aren't going to last very long.
Old Apr 25, 2002 | 01:26 AM
jspecracer7's Avatar
1JZ powered
You don't necessarily need bigger injectors, but a fuel pressure regulator.
I know that Dragon ran an A/R .50 60-1 wheel with a .86 exhaust side for OVER 1 1/2 YEARS on a street ported motor and didn't blow the engine. The motor blew a water seal.
He had STOCK injectors at .8 kilos, but eventually turned it up to 1.0 kilos when he got the power FC.
Old Apr 25, 2002 | 01:41 AM
93TTRX7's Avatar
without a good intercooler you run the risk of pre detonation running pump gas with boost higher than 12 psi
Old Apr 25, 2002 | 02:46 AM
voodooracing's Avatar
also, must consider if the pump can maintain the pressure if running much higher-than-stock fuel pressure with rising rate FPR.
Shainiac
Jul 17, 2019 02:20 PM
Bauer778
Nov 4, 2015 04:42 PM
zxrazorxz
Sep 14, 2015 07:21 PM
High_Carb_Diet
Power FC Forum
Sep 5, 2015 09:07 AM
