NE RX-7 Forum Serving ME, NH, VT, MA, RI, CT, NY, NJ, DE, PA, OH, WV, MD and VA
local machanic?
Old Mar 10, 2008 | 08:06 PM
19-r-e-d-79's Avatar
local machanic?
i am in north jersey and was wondering if there is a local Rotary machanic who can come take a look at my 79 .
Old Mar 10, 2008 | 08:33 PM
Rx7aholic's Avatar
what's wrong with it? And where in north jersey are u exactly?
Old Mar 10, 2008 | 08:37 PM
1QWIK7's Avatar
White chicks > *
PM rotaryexperimentseven or goodfellasfd3s.
They are from north jersey and they do good work.
Old Mar 10, 2008 | 10:43 PM
it will idle but as soon as i touch the gas peddle it dies .. it will run with the choke out but but thats it .. idle just barely stays running (400rpm) .. i am in passaic.
Old Mar 11, 2008 | 08:50 AM
1QWIK7's Avatar
White chicks > *
Did you check your fuel filter/fuel pump?
Old Mar 11, 2008 | 06:13 PM
replaced the filter and the fuel pump is making a bit of noise but is still running .. the car will rev with choke out and just dies anywhere under 2k i am thinking it is a cloged jet or something .. would like someone to take a look so i can get it fixed if need be ..
Old Mar 13, 2008 | 06:22 AM
bump
Old Mar 13, 2008 | 06:27 AM
AnthonyNYC's Avatar
Stay tuned...
Did you PM these guys?
Old Mar 13, 2008 | 10:25 AM
Rx7aholic's Avatar
Is the carb oem or holley? If it's oem then u need to do some adjustment on the carb I believe there is 2 screw? Can't remember exactly, also are u still using points on the dizzy? Also If I have the time this saturday I can look at it. Call me at 917-567-3385
khris
Old Mar 13, 2008 | 05:38 PM
car is 100% stock .. so it has the nikki carb on it . it still has the points on the distributor .. i will give you a call on saturday morning to see if you are available .. thanks khris
Old Mar 16, 2008 | 06:30 PM
update .. i was told by a non rotary machanic i know it is more then likley a vacuum problem .. when i cover the air cleaner horn the car does not stop running ... khris i called and left you a message .
LongDuck
Oct 7, 2015 08:12 PM
