Radio Install question
Old Mar 5, 2008 | 06:14 PM
gst19psi's Avatar
Hey I'm new to the site. Just curious if anyone has a link that details a radio install?
Old Mar 9, 2008 | 09:58 PM
FearNoPiston's Avatar
FREAK ALL OUT!!!
what do you want to know?
Old Mar 11, 2008 | 06:31 AM
gst19psi's Avatar
Basically how and which panels to pull, screws and on those said panels are located. You stuff like that. Dont feel like breaking anything.
Old Mar 11, 2008 | 07:39 AM
certifiednut's Avatar
Mike Honcho
first you need to specify what year of car you have, then you need to look in the correct section for your car, then either look up a fsm (factory service manual) or go buy a haynes manual
Old Mar 12, 2008 | 10:15 AM
rx7fan1903's Avatar
Drifter Fo' Life
we need details, like the year of the car? Type? is it an FB, FC (YAY!) or FD?
Old Mar 13, 2008 | 11:17 AM
gst19psi's Avatar
its an 93 FD
Old Mar 13, 2008 | 11:28 AM
RotaryBred's Avatar
Lost You in the Rear View
i didn't have to remove my stock radio because it was done for me, but usually there are 2 holes on either side of the radio. i just stick a u shaped piece of coat hanger into both sides (about 3-4 inches of length goes inside the holes) and push them outwards while pulling towards you. this should release the clips holding the radio in. now all you need is the proper harness adapter (or wiring diagram should you choose to hardwire)
good luck
Old Mar 13, 2008 | 11:38 AM
FREAK ALL OUT!!!
What ^ He Said Or Get Ford Radio Removal Tools They Are Like Twelve Bucks If You Cant Get The Coat Hangers To Work, And Also Do Not Whatever You Do Cut Your Harness There Is An Adapter Carried By Pretty Much Every Local Shop That Will Plug Right In. By The Way If It Is Bose It Will Be A Little More Work That A Standard Radio.
Old Mar 16, 2008 | 10:22 AM
gst19psi's Avatar
So ur telling me that the factory stereo is installed with a simple clip method like and aftermarket radio. No its not a bose.
Old Mar 16, 2008 | 10:37 PM
FREAK ALL OUT!!!
just look here http://images.google.com/imgres?imgu...US262%26sa%3DN
Old Mar 18, 2008 | 09:55 PM
gst19psi's Avatar
nice thanks alot.... I thought it would be more involved.
Old Mar 21, 2008 | 11:07 PM
gst19psi's Avatar
Well I finally had a chance to get the radio out and well to my surprise the wire harness has been chopped up its pretty bad. If anyone has a spare laying somewhere that would be great or so simple directions on hardwiring it that works to.
Old Mar 26, 2008 | 01:12 PM
FREAK ALL OUT!!!
Here is the wire diagram for a 93 fd without bose, I suggest always testing just to be safe.
Wire Function Color Note Fuse # Size Location
+12V DC Battery(Constant) Blue/red Room 10 amp Joint box
Switched Accessory Blue/black Cigar 15 amp Joint box
Ground Black
Power Antenna Green/orange
Remote Turn On(output) Green/orange Also light green/black, thru the radio relay
Left Front + Green To the door speaker & to the center speaker amplifier
Left Front - Blue To the door speaker & to the center speaker amplifier
Right Front + Red To the door speaker & to the center speaker amplifier
Right Front - White To the door speaker & to the center speaker amplifier
Left Rear + Yellow/green
Left Rear - Yellow/blue
Right Rear + White/blue
Right Rear - Blue/yellow
Th0m4s
Feb 26, 2019 02:04 AM
gabescanlon
Interior / Exterior / Audio
Aug 11, 2015 05:59 PM
