over boosting ( Automatic Trans)
Old Apr 22, 2002 | 04:50 PM
x-911racer's Avatar
Newbie
Having a problem with over boosting on my Automatic FD
I have just installed a full exhaust system, ECU piggyback, etc.. the boost is in a normal pattern between the two turbos but between shifts it will very quickly creep to 15 psi unless i quickly lift off the gas.
this happens in hold mode or in drive mode any Ideas how to control this
Thanks
Old Apr 22, 2002 | 06:52 PM
moralesrx7's Avatar
over boosting
i have the same problem iam currently trying to design a blow off valve that works off the rpm voltage as the voltage raises it closes but at any decrease it opens but besides that you cant do anything i just completely let go off the gas as i shift to 2nd and so on as if you where driving a stick
Old Apr 22, 2002 | 07:03 PM
mjw's Avatar
mjw
I had an overboosting problem as well when I started to mod my car, not boost creep from the small wastegates, but it would just spike right up like that. Until I can afford an ProfecB or the like I yanked out the stock wastegate/prespool hoses and installed some bleeder valves from Home Depot, cured the problem instantly.. and now I can adjust my prespool/boost which is great. Check out this link:
http://www.robrobinette.com/boost_controller.htm
Matt
93 SSM
Old Apr 22, 2002 | 08:02 PM
ejmack1's Avatar
Lawn Ornament
Well the tranny should shift fast enough that it does not have this problem, i remember having a similar problem... but oh yeah... that was with no WG solenoid connected
Old Apr 22, 2002 | 09:33 PM
CantGoStraight's Avatar
What's your point ?
Put larger pills in the waste gate and precontrol hoses to lower your boost. With everything you've done a boost controller of some sort is in order even if it's the manual one.
befarrer
Old School and Other Rotary
Oct 5, 2015 03:30 AM
High_Carb_Diet
Power FC Forum
Sep 5, 2015 09:07 AM
gabescanlon
Sep 5, 2015 12:09 AM
