(ENGINE) Cleaning and painting a 12A
Old Feb 4, 2008 | 11:15 PM
blwfly's Avatar
kiwi from downunder..
well the last 3 days i spent scrubing the engine with parts cleaner i used a large soft metal brush a smaller one and a tooth brush took alot of hour's and a few rags busted my knuckles alot lost some blood but it was worth it
i took the engine to the shop at work and used the small presure washer"3500psi" i used castro super clean to help remove any parts cleaner or oil and to help losin any caked on crap i missed..
i would recomend tapin the ports off i just loaded the engine with oil before washing and made sure everything was oiled internally..
Attached Thumbnails (ENGINE) Cleaning and painting a 12A-cimg0680.jpg   (ENGINE) Cleaning and painting a 12A-cimg0678.jpg   (ENGINE) Cleaning and painting a 12A-cimg0681.jpg
Old Feb 4, 2008 | 11:26 PM
teddyrx2's Avatar
One Luv "Till The End"
very clean...what you running, what setup, intake, exhaust so on and so forth
Old Feb 4, 2008 | 11:35 PM
blwfly's Avatar
my own modded nikki stripped to essentials rb header to a 3" exhaust the reason fo that is i have a t2 fo the car.
practicaly its just a engine to get me car mobile just in cause my 1ton toyota gives in.. plus i miss doing cookies at the boat ramp parking lot
Old Feb 4, 2008 | 11:42 PM
kevinbtz's Avatar
Shell 93
Looks Good!!
Old Feb 5, 2008 | 12:13 AM
RW-7's Avatar
Moderating the Trochoid
Hey thats one clean lookin motor mang!
Old Feb 5, 2008 | 12:23 AM
blwfly's Avatar
im gonna shot some clear paint on try retain the look see if that helps
Old Feb 5, 2008 | 01:03 AM
twinkletoes's Avatar
Looks great, Love seeing clean motors. Good job
Old Feb 5, 2008 | 01:20 AM
kevinpowers's Avatar
hell yah brother the boat launch is where my car has seen its last 150 miles of use in the past 6 months
Old Feb 5, 2008 | 03:05 AM
takhay's Avatar
Wow, so THAT'S what the engine looks like... lol.
Is that engine stock, or have you put a finish on those housings? My engine's been dirty-grease-colored for as long as i can remenber... hard to imagine mine that shiny...
Think i've found a new weekend project...
Nice work!
Old Feb 5, 2008 | 04:50 AM
mazdaverx713b's Avatar
Have RX-7, will restore
that looks really good!!! those irons will cut your knuckles easialy as they are known to have razor like edges!
Old Feb 5, 2008 | 05:45 AM
Latin270's Avatar
Hard work paid off nicely!
Old Feb 5, 2008 | 07:59 AM
Kentetsu's Avatar
Looks very nice man. I still need to pull my motor to correct a flywheel compatability issue, and when it comes out it will definitely be getting the same treatment...
Old Feb 5, 2008 | 10:18 AM
fbatman's Avatar
+a bunch on looking great! curious though- is there a finish on the housings/front cover? were they previously polished? I was going to do this to my current motor before it went in, but got lazy/time crunched and never got around hauling the motor over to a buddys place to do it...was also going to pressure wash the seats-grassroots ms did an awesome write up on pressure washing things in/on your car to make them look new again ha...
Old Feb 5, 2008 | 10:30 AM
blwfly's Avatar
no polishing no paint no finishing materials
just good old fasion elbow grease with parts cleaner and wire brush and tooth bruch for around bolts then the pressure washer did the rest just have to be carefull not to blow holes in ya front cover gaskets..
thanks everyone didnt expect so much good
Old Feb 5, 2008 | 11:03 AM
Vashner's Avatar
Looks sweet. Like it was just off the assembly line.
Old Feb 5, 2008 | 07:38 PM
blwfly's Avatar
just sprayed 3 coats of high temp clear today should handle 700* it says
should look good for a longtime to come now
Attached Thumbnails (ENGINE) Cleaning and painting a 12A-cimg0682.jpg   (ENGINE) Cleaning and painting a 12A-cimg0683.jpg   (ENGINE) Cleaning and painting a 12A-cimg0684.jpg
Old Feb 5, 2008 | 07:42 PM
aussiesmg's Avatar
Thunder from downunder
Nice Blowie, looking good
Old Feb 5, 2008 | 08:40 PM
rx-freak's Avatar
That keg looks great! I like the nakedness of it. lol
Old Feb 5, 2008 | 09:39 PM
StealthGXL's Avatar
Wow I can't believe how clean the housings and front cover are, sweet!
Have a question for ya, do these studs serve any purpose? Or can they be taken out?
Old Feb 5, 2008 | 09:44 PM
blwfly's Avatar
i belive they are for the air condition unit. and yes they can be takin out.
Old Feb 6, 2008 | 03:43 AM
7aull's Avatar
RX HVN
HA! Real Men do all this detailing with the engine still in the CAR! -Right Ray!?
Seriously tho , nice! Pop out the oil filler and paint it up to compliment the block.
Yeah, bolts for air cond and power steering. Attach 2 nuts to the stud, wrench the INNER one and they spin right out...
Stu Aull
80GS (cleaned the Old Fashioned Way)
Alaska
Old Feb 6, 2008 | 03:50 AM
Keegan's Avatar
looks real good now you just need to put it iin the car
Old Feb 6, 2008 | 03:28 PM
fbatman's Avatar
awesome! incredible to hear thats how shiny they can get w/o polishing!! let us know how the clear coat holds up! where did you get the clear coat, and what kind was it? did you have to apply it with a gun or was it a hand held spray can?
Old Feb 6, 2008 | 08:24 PM
blwfly's Avatar
Stu Aull
Alaska
well im a real bloke and bloke's to it right the first time
Old Feb 6, 2008 | 08:27 PM
blwfly's Avatar
its just a rattle can you can buy it any auto parts store..
just make sure its high temp.. so it wont discolour later.
