Power FC Non. Sequential Setting in PowerFC
Old Feb 21, 2008 | 08:50 PM
93RedDragonFD's Avatar
Ok, so i finally got my car running again, but its not boosting correctly. I did a non. sequential conversion to the twins and i think there is a setting somewhere in the PowerFC where you can change the setting from sequential to non. sequential. Anyone know, it would really help...
Thanks,
Zach
Old Feb 21, 2008 | 08:56 PM
cewrx7r1's Avatar
Eye In The Sky
When I tried to use the PFC for non-seq boost control, I did not like it.
I then went to a manual control and it worked fine. Later I went with a EBC as it was in cabin adjustable.
Old Feb 21, 2008 | 09:20 PM
Thanks, but its not really the boost control that i'm asking about...I dont think think the PowerFC is reading that the twins have been switched to non. sequential. I will get to about 9-10 pounds fine then it will fall flat on its face and the car will jerk. I just thought maybe there was a setting that you could/have to change when switching from seq. to non.seq. Am i wrong???
Old Feb 22, 2008 | 10:26 AM
cewrx7r1's Avatar
Eye In The Sky
I do not think it is boost control. You can verify by running manual boost which is easy to do.
We are assuming that you have averything properly setup in your PFC.
Go to page 28 of your manual, the pargraph next to the last large black dot.
Old Feb 23, 2008 | 05:07 PM
kerry chandler's Avatar
Main screen on the commander
ETC
Function Select
Seq Turbo Cont on/off
Old Feb 24, 2008 | 08:24 PM
Thanks, are all EBC's the same, or is one better then the other? Kind of on a low budget...
Old Feb 25, 2008 | 08:38 AM
cewrx7r1's Avatar
Eye In The Sky
Did you calculate when you would have fuel cut on boost and what that pressure was as compared to 9-10 psi boost?
streetlegal?
Mar 17, 2022 02:46 PM
Skeese
65
Mar 28, 2017 03:30 PM
Snoopy FD
Dec 8, 2015 01:45 PM
