Sponsored by: CARiD
pilot bearing
Old Feb 19, 2008 | 06:05 PM
rx7306vert's Avatar
pilot bearing
Has anyone used a bronze bushing in place of the needle bearing? I am thinking of making one out of bronze bushing stock. What do you think?
Old Feb 19, 2008 | 07:05 PM
Doc-1's Avatar
Doc-1
Really Really BAD IDEA. Bronze is much softer than harden steel. What I would like is an external grease fitting.
Old Feb 19, 2008 | 07:53 PM
jgrewe's Avatar
GET OFF MY LAWN
All the time, use oilite, not just bronze.
Old Feb 19, 2008 | 08:13 PM
Matt Hey's Avatar
Old School
There are some bronze alloys that are strong and hard. Some are heat treatable and as strong as some hardened steels. Most bronze alloys provide low friction/wear and have good fatigue resistance which is useful for bearings. Choosing a suitable material is only part of engineering and testing a new pilot bearing though.
http://www.onlinemetals.com/bronzeguide.cfm
http://en.wikipedia.org/wiki/Bronze
Old Feb 19, 2008 | 08:26 PM
Why? the oem available from mazda works just fine.
Old Feb 20, 2008 | 06:54 AM
rx7306vert's Avatar
I ordered a piece of 932 bearing bronze that has tensile strength of 35,000psi and brinell hardness of 65. I think .002 to .003 clearance would work I"m not sure of the type of grease to use I have never seize compound in mind. Does anyone have better suggestions. I don"t have enough posts to pm. If anyone would like to speak with me please leave a phone #. Thanks
Old Feb 20, 2008 | 10:35 AM
RETed's Avatar
Wondered about this same idea before...
Consulted an ME about this, and it's a step backwards.
The needle bearing is superior to any kind of bushing for this application.
I used to be paranoid about the stock pilot bearing, since I've broken them before.
Yes, the stock pilot bearing can be fragile.
Since I figured out how to stop damaging them on installs, I have no worries now.
-Ted
ls1swap
Jun 3, 2024 03:25 PM
Vartok
16
Oct 8, 2015 04:49 PM
