How much HP?
Old Apr 21, 2002 | 02:09 AM
RX-7 GT's Avatar
HyperREV.com
How much HP?
hello,
as an estimate, what hp and what fuel would i need to support this combo on a s4 13bt. such as injector size etc.
3" dp/exhaust - no cat
intake/tid
possibly a fmic not sure yet.
on around 9-10psi at the most on the stock turbo.
thankyou,
brandon
Old Apr 21, 2002 | 02:20 AM
Scott 89t2's Avatar
SOLD THE RX-7!
unless you port your wastegate alot you'll be running towards 15... but at 9-10 a bigger fuel pump should be fine by itself.
Old Apr 21, 2002 | 05:51 AM
NZConvertible's Avatar
I'm a boost creep...
Like Scott said, you'll have no chance of keeping boost at 10psi with an unported S4 wastegate and a 3" exhaust. Get it ported or swap the turbo and manifold for S5 items.
If you do either, and manage to keep boost down to 10psi (any more will kill the stock turbo anyway), you will be within the limits of the stock injectors. These are big enough for ~300fwhp @ 80% duty. I'd guess you'd be around 240-250fwhp. The pump's a good idea though.
