Power FC looking for power fc for FC3S anyone?
Old Feb 6, 2008 | 08:24 PM
komanji_klub's Avatar
hey guys, I'm looking for the now discontinued power FC for my FC3S TII anyone know where I can get my hands on one or does anyone have one up for sale?
Old Feb 6, 2008 | 09:05 PM
djmtsu's Avatar
DGRRX
eBay.
Bring your checkbook.
Old Feb 6, 2008 | 10:14 PM
cezonetheillest's Avatar
if you check out this link it will tell you how to put a series 6 power fc into your series 5 without the adapter harness.
http://www.rotary-imports.de/space/PFC_install_FC.pdf
its got some good info in it and also it has the series 4 install
Old Feb 7, 2008 | 04:46 AM
Banzai-Racing's Avatar
Rotary Specialists
We have installation kits for the FD PFC for both the S4 and S5, which come with all the sensors and harnesses. This is a much less expensive solution to the AP unit.
Btw-iwans directions has errors, we tried to tell him how to correct it.
Old Feb 7, 2008 | 08:46 AM
Iwan's Avatar
Hi there,
what kind of errors did you found? Converted many cars like described on my how-to with no problems at all. All of them are running fine, so would be surprised to read about any errors.
Received your note about using 2 FC trailing coils, but I don't prefer this solution.
REgards
Iwan
Old Feb 7, 2008 | 10:30 AM
Rotary Specialists
Just as an example: Page 6
You have 4X and 4Z both listed as the "injector secondary front"
This is a great way to blow an engine
You say that the S4 is full range throttle, this is wrong it is only a narow range TPS, so the instructions are totally wrong for this section
Next you talk about the fuel pump not being controlled by the ecu, this is not completely wrong, but there is no need to wire in a new relay, it just taps into the COR as it states in our installation instructions.
This is just page 6, the whole thing is full of errors.
Old Feb 8, 2008 | 12:08 PM
Iwan's Avatar
OK, agree to my "copy & paste" error on injector pinout. Also found some misspellings there and will correct is soon.
So update is comming!
Thanks and REgards
Iwan
rx7shirley
Sep 2, 2015 02:11 PM
