Whats wrong Here
Old Apr 20, 2002 | 10:11 AM
Kastle's Avatar
Exclamation Whats wrong Here
okay guys im new here. I have an 87 rx7 GXL with 174,000 KM on it . This problem started in november when i couldnt start my car (it wasnt flooded i know about that stuff) i got it pushed started fine parked it about 45 min later started fine , I went home parked it, next day It wouldnt start. Tryed push starting it on a hill by my house but it would'nt go ( it tryed to go but wouldnt ) . its making this whining noise when i go to start it now. I think its the starter but why wouldnt i be able to push start it ? any info would be greatly apreciated
Thanks guys ...
Old Apr 20, 2002 | 10:29 AM
UniqueTII's Avatar
Slow and old
How do you know it wasn't flooded? My TII whines when it's really flooded.
Old Apr 20, 2002 | 10:33 AM
Kastle's Avatar
Because i let it sit all winter and it still does it and i also did the fuse trick the other time too .
Old Apr 20, 2002 | 10:41 AM
SaabGuy's Avatar
injectors will leak over time. leaking is inevitable. Next time try removing the 40a fusse under the hood (while the car is running) when you want to park the car for an allotted time where the problem usually occurs. If the fuse trick works then you have leaky injectors. You can wire a switch to your fuel pump or clean your injectors.
Old Apr 20, 2002 | 10:43 AM
Kastle's Avatar
Yea but the problem is i can't get the car started it wont push start either
Old Apr 20, 2002 | 10:51 AM
SaabGuy's Avatar
stop forcing it cause you could be damaging a housing due to a loose seal or major carbon buildup.
Pull the plugs and try getting some atf or seafoam in there. Marvel mystery oil works as well.
What seems jammed up? You should be able to turn the engine over by hand or a small wrench. very little friction.
Old Apr 20, 2002 | 10:57 AM
Kastle's Avatar
mmm , how would i be able to turn the engine over by hand ???
Old Apr 20, 2002 | 03:55 PM
Kastle's Avatar
??? anyone
Old Apr 20, 2002 | 06:59 PM
Kastle's Avatar
C'mon ANYONE PLEASE I NEED THIS ****** THING FIXED FAST, ITS GETTING WARMER HERE EVERYDAY !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Apr 20, 2002 | 07:24 PM
Aaron Cake's Avatar
Engine, Not Motor
Read the replies again. They contain the answers....
Here's my suggestion. Remove the top two spark plugs. Into each hole, pour about 1.5 ounces of 10W-30 oil. Leave the spark plugs out, and turn the engine over slowly by hand by moving the front pully. Turn it over a few times to get the oil circulated. Now put your plugs back in, make sure the battery is fully charged, and start the car...
Others may tell you to use ATF instead of oil, but I suggest oil since it is easier on the engine than ATF...
Old Apr 20, 2002 | 10:25 PM
QC Motorsports
Wouldn't 2 cycle engine oil work better than regular oil since it wont leave all that carbon behind? Just a thought I'm not sure. Please correct me if I'm wrong, I don't want anyone to mess up their engines cause of me.
Charles
Old Apr 21, 2002 | 12:33 AM
mr_vaughn's Avatar
Chillin
I had a similar problem and at random my fc3 would not start but it would start perfertly if i pushed started it.
my starter did not turn over and hear the rotary rotate,but i had the starter changed and it now starts up perfectly
Old Apr 21, 2002 | 09:37 AM
Kastle's Avatar
Talking
Wicked guys thanks for all the help , ill go give it a try later and keep you all posted on how things went .
Thanks again its greatly appreciated
Kastle .....
Old Apr 24, 2002 | 09:01 AM
Kastle's Avatar
OKAY........I think i now have compression the car wants to start but its still not going , its so close tho.. Could one of the spark plugs not be firing?? would that make a difference , PLEASE HELP !!!!!
Old Apr 24, 2002 | 10:51 AM
95R2-89TII Ground Zero's Avatar
Banned
You should be able to start the car by doing just that. Pour a small amount of oil in the leading plug holes, then put the pluge in and turn the front pulley by hand to circulated the oil and gas. Then try to start the car.
Old Apr 24, 2002 | 04:31 PM
Kastle's Avatar
i didi that already
Old Apr 24, 2002 | 07:56 PM
RX-7Impreza's Avatar
I am the Anti-Ch(rice)t
is the only reason that you think it isnt flooded because it sat all winter like this?????
a rotary will stay flooded until you unflood it, i say try the efi fuse trick
or push the gas pedal in all the way and try to crank it, this cuts off the fuel.
Justin
dona1326cosprings7
Oct 29, 2015 06:47 AM
pfsantos
Sep 30, 2015 01:29 PM
